February 20, 2014, 11:20 |
help with idelchik resistance calc.
Im trying to calculate resistance coefficiants of simple perforated plate by using idelchik handbook. the plate is 1mm thick, 70% open, with 7mm dia. holes, and around 150x150mm in size. the approach air velocity is around 5 m/s. i want to clarify some things as this is the first time i do this calculation : 1. Hydraulic dia. Dh is defined as 4*fo/Pio , where Pio is the perimeter. perimeter of what - a single 7mm hole or the whole channel section (150*4) ? 2. Can you point me to a reference/table where i can find resistances of perforated plates ? i didnt find somthing like this on the web. thanks! |
Viscous resistance coefficients in porous medium | fpingqian | FLUENT | 50 | June 26, 2019 01:55 |
Inertial Resistance and Viscous Resistance Data | ravitejakatragadda | FLUENT | 5 | May 10, 2018 04:16 |
Ship resistance | tobino | FLUENT | 0 | June 27, 2011 20:31 |
adapt viscous resistance based on velocity / UDF | Häwimeddel | FLUENT | 2 | April 20, 2009 10:08 |
tube bank inertial resistance coefficients | Brian | FLUENT | 0 | September 8, 2004 09:04 |
