Symmetry Boundary Condition
Old   November 17, 2005, 16:57
Default Symmetry Boundary Condition
Noname
when we model flow past a cylinder how do we mathematically express the symmetry boundary condition when we want to do calculations only for the half domain.
Old   November 17, 2005, 17:43
Default Re: Symmetry Boundary Condition
boling
keep all the physical variables same except reverse the normal velocity component (normal to the symmetry plan)
Old   November 17, 2005, 20:57
Default Re: Symmetry Boundary Condition *NM*
Mani
Old   November 18, 2005, 13:27
ramp
The flow regimes for the flow across a circular cylinder are: (a) steady flow without separation (b) steady flow with symmetric vortices behind the cylinder, (c) laminar vortex shedding flow (d) 3-D unsteady flow, etc
Upto to the regime (b), the computations can be carried out using half domain because the flow is symmetric in the upper and lower half of the domain. In case of Newtonian flow, the occurance of laminar vortex shedding is approx @ Re=46 (few have reported 49) and so the half domain can be used for Re < 46 ......
Old   February 18, 2014, 02:54
Question symmetry boundary condition
vut
vut is on a distinguished road
Hi all,
I have the following geometry: 3 cylinders (2 concentric and the remaining excentric). So, the geometry has a symmetry plane.
Have I define each plane of each cylinder as symmetry?
Thanks in advance,
vut
vut is offline   Reply With Quote
Old   February 18, 2014, 15:55
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Not sure I understand your question as I did not understand what you are trying to simulate.
Anyways, as ramp already said, the fact that a cylinder has a symmetric shape doesn't mean that the resulting flow will also be symmetric. In most of the cases it will not actually.
lovecraft22 is offline   Reply With Quote
Old   February 19, 2014, 04:43
Post Geometry of the injector
vut
You can see in the attachment the geometry of the injector that I want to simulate.
In fact, I hope to be able to consider a half of the geometry. Thus, I define three surfaces as geometry planes. The simulation is converged. However, the mass flow rate I obtained is quite small comparing to that measured.
Let's assume that I define a pressure inlet and a pressure outlet.
My first question is:
do you have an idea to mesh this geometry?
And the second one is:
what are possibly the reason of low mass flow rate in this case?
Thanks in advance,
Old   February 19, 2014, 13:11
lore
I guess it is ok to use a symmetry plane in this case.
What do you mean with "how to mesh this geometry?"
Can you set the inlet condition with a specified massflow instead of pressure?
Old   February 20, 2014, 16:48
Question Mass flow rate not matched
vut
I mesh each cylinder sepately. Then I assembly them by tmerge. Everything seems OK.
The problem I have is the following:
I set the inlet as pressure inlet and the outlet as pressure outlet.
However, the mass flow rate given by Fluent does not match the experimental one!!!
Some body has a great idea to solve this stuff?
Thanks in advance,
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
Mixed/Robin boundary condition aaev OpenFOAM Bugs 2 December 15, 2011 14:03
Slip boundary condition what is inside normunds OpenFOAM Running, Solving & CFD 2 June 4, 2007 06:45
Regarding SYMMETRY boundary condition Praveen Athanki FLUENT 0 March 27, 2000 13:30
