February 27, 2007, 15:11 |
GNU Plot doubt
Hi folks,
some time ago I did something in GNU Plot that I can't remember. I loaded a data file which was still being written and after each update GNU plot automatically reloaded and refreshed the resulting plot. Does anyone know which command is used for doing it? Thanks Renato. |
February 27, 2007, 16:37 |
Re: GNU Plot doubt
c Fortran-gnuplot interaction for real-time animation using named pipe
c c This is a simple example of how gnuplot can be used to create c real-time animation of data produced by running fortran 77 code. c c I put it in the searchable directory in a hope that it can be useful, c but no guarantees of any kind: use it at your own risk. Too many c frames per second can hang you system heavily. c c To understand how it works, you need to know what a named pipe is, and what c plot '-' means in gnuplot: read the manuals. c c And, PLEASE, if you know why a.out > FIFOfile works c but just a.out does not c even though the gnuplot commands are written to the pipe and not c to the standard output, send me an explanation to c chernysh@soton.ac.uk (Sergei Chernyshenko) or c by other means, see http://www.afm.ses.soton.ac.uk/ -> People. c c How to use: c c at the linux command prompt, type mkfifo FIFOfile c compile this file and name the executable a.out . c in an xterm window type gnuplot < FIFOfile c in another window type a.out > FIFOfile c enjoy c c do not use too many frames per second, the computer may hang. c c second(x) gives the CPU time in seconds. Replace if unavailable. nframe=0 open(1,file='FIFOfile', status='unknown') write(1,*) 'set xrange [-10:10]' write(1,*) 'set yrange [-2:2]' write(1,*)'set title \'Demonstrating animation Fortran-gnuplot' 1 ,' via named pipe\'' close(1) 1 call second(x) c 15 frames per second: if(15*x.gt.nframe) then nframe=nframe+1 open(1,file='FIFOfile', status='unknown') write(1,*) 'plot sin(x-',x,'),',' \'-\' w lp' write(1,*) 0.2 write(1,*) 0.3 write(1,*) 0.4 write(1,*) 0.5 i=(x/10) i=i*10 write(1,*) (x-i)/10. write(1,*) 0.7 write(1,*) 0.8 write(1,*) 0.9 write(1,*) 'e' close(1) endif goto 1 stop end |
Display Modes | |
Plot on a curve | Monica | FLUENT | 1 | July 11, 2012 01:24 |
A girl fail to plot velocity profile when mesh changes + Wall function | asherah | STAR-CCM+ | 0 | February 19, 2010 18:45 |
Transfer low-res graphic file plot to excel plot | quarkz | Main CFD Forum | 3 | April 9, 2009 14:54 |
graph plot | anindya | Main CFD Forum | 2 | September 17, 2003 13:00 |
why can't I plot Y+ value? | Jiaying Xu | Siemens | 2 | August 18, 2001 11:56 |
