Fortran Warning and error
Hello All,
I've got this warning when I ran my code in Fortran: "warning LNK4084: total image size 377360384 exceeds max (268435456); image may not run" What is this warning and how it could be fixed. Thanks M.M |
Re: Fortran Warning and error
I guess you are using visual fortran under windows. I think this message comes from the limitations of old operating systems (i.e. windows 98 ...) that did not accept executables bigger than 256Mb. "image may not run" => if it runs, do not pay to much attention to it ;) Regards |
Your warning is due to lack of memory to load your program due to the size of the memory fixed allocated. You can work out it by using dynamic memory allocation (it's a Fortran 9X feature, so, don't try to do it with old F77 compilers). You can do it according to the following example.
! fixed allocated real*8 :: HugeArray(1000000000) ! dynamica array real*8, allocatable :: HugeArray(:) n = 10000000 allocate(HugeArray(n)) ! use your HugeArray ! Freeing the memory previously allocated deallocate(HugeArray) Cheers Renato. |
You must have a stack size option somewhere in your compiler. Simply increase with respect to the default value (usually 2MB).
Fortran warning
Hi
I have this warning when I compile my code: A jump into a block from outside the block may have occurred" How could I fix it? Thanks, snow |
