March 19, 2014, 05:57 |
CFD on Aerofoil Flaps
Ryan Paul Galea
Hi guys,
I am currently working on investigating what effect on Lift coefficient various types of flaps have on an NACA2412 aerofoil. A Reynolds’ number of 100,000 is initially considered. I’ve done some experimental tests in a wind tunnel for these types of profiles: • Plain Flap • Split Flap • Slotted Flap • Fowler Flap • Handley-Page LE Slat After comparing the experimental analysis with those obtained from FLUENT, it resulted in lift coefficients for CFD being much larger than those obtained from experiments (Experimental data for 0 degrees AoA came out to be around 0.22 – 0.4 while those obtained in CFD are all > 1.18). I did a grid independence check and verified convergence by assessing the graph of lift coefficient vs Number of Iterations. I used a density-based solver with a Laminar model due to the low Reynold’s number. I also tried out the Spalart Allmaras, k-w SST, Realizable k-e and Transitional k-kl-w turbulent models. I also tried to lower the explicit-Under Relaxation factors where necessary but all seem to hinder the same results. Is there anyone who might have encountered the same problem or is this behaviour normal due to poor drag calculation on the model? Cheers |
March 19, 2014, 16:39 |
#2 | |
But one order of magnitude seems to be too much. It might happen that you set wrong rederence lengt or velocity in fluent or/and wrong direction of force evaluation. Try to do the following: take your airfoil and run inviscid in x-foil with unit chord (this takes 5 minutes to learn and fraction of second to run), then do inviscid in FLUENT with your former fluent settings. If the difference in Cl will be big then the problem is in your fluent settings. If not, the problem is in the turbulence modelling or/and measurements. Trufaldino |
March 19, 2014, 16:45 |
#3 | |
Filippo Maria Denaro
Rep Power: 71 |
well, but the Re number should ensure a laminar flow along the profile, isn't it? maybe the grid resolution is not adequate and the used scheme is too dissipative ... |
March 19, 2014, 16:55 |
#4 | |
I think the numeric dissipation will not lead to error of one order of magitude for the lift coefficient. This is just to chek that there is no big error in the Fluent settings. |
March 20, 2014, 09:28 |
Ryan Paul Galea
Appreciate for your reply guys.
I did arrange the reference value of Area appropriately Trufaldino. I also run the calculation for a unit length just like you said while setting the reference values to match that geometry. I got the same results using an inviscid model since it’s a laminar flow. FMDenaro, mesh-wise, I made use of a tet-mesh in a C profile using inflation layers around the aerofoil, making sure that the y+ is around 1 (it varied between 0.7 and 2), so that shouldn’t be a problem either. Clearly the problem started when modelling the aerofoil with flaps since when I ran an NACA2412 profile, CFD results matched perfectly experimental data. I guess it’s the turbulence model then; but I’m still sceptical on how it can lead to a large difference between experiments and CFD. Knowing that turbulence models give unreliable data for transitional flows, can the problem be a transition region somewhere close to the flap, which is leading FLUENT to give wrong data? |
March 20, 2014, 15:43 |
Jon
Rep Power: 13 |
I would say its like to be a mismatch in the setup/geometry between CFD and experiment.
Have you matched blockage ratio? Have you replicated the physical 3D nature of the experiment? Are you measuring the AoA in the same way? Have you non dimensionalised the same way as they did? I would double check those first. |
March 23, 2014, 08:17 |
Lefteris
Rep Power: 15 |
I would also add: Are you sure you've used the correct boundary conditions? Irrespectively of the grid convergence study, are you sure that your boundaries don't affect the solution elsewhere in the domain? And, why are you using a density-based solver?
Lefteris |
STAR-Works : Mainstream CAD with CFD | CD adapco Group Marketing | Siemens | 0 | February 13, 2002 12:23 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 21:10 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | September 13, 2000 04:48 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | August 21, 2000 04:49 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
