Re: Transition Model
Old   September 20, 1999, 18:30
Default Re: Transition Model
Michael K H Kim
I work with a CFD code that is a Navier-Stokes solver with Baldwin-Barth one equation turbulence model. I am considering the development of transition model into this code. The field of application is in modelling flows around fan blades.
I would appreciate any kind of input on this topic.
Old   September 23, 1999, 13:30
Hongjun Li
(1).make sure the scheme used in the original code is time-accurate. if not, you may need to change the scheme. (2).if 3-D, change the equations from absoluate frame into rotation frame using relative velocity, with centrifugal and Coriolis terms, and (3) if for compressible flow, you may want to use rothalpy insteady of enthalpy in the energy equation.
HLI
Transition kappa omega turbulence model mannobot FLUENT 0 June 9, 2010 04:11
transition onset - SST:Gamma Theta Model Prad CFX 4 February 21, 2007 09:32
where to set CFX Transition Model? steven CFX 6 January 17, 2007 11:19
model transition nico FLUENT 0 February 8, 2004 09:04
k-omega model and unsteady transition Jens Thurso Main CFD Forum 1 May 4, 1999 09:50
