boundary conditions and artificial viscosity
Old   March 31, 2014, 11:56
Default boundary conditions and artificial viscosity
Joachim
Joachim is on a distinguished road
Hey everyone!
I am using the Jameson dissipation terms in my solver, and I was wondering what to do at the boundaries. I read in some papers that the dissipation was sometime set to zero at the wall. Why is that so? why shouldn't I compute the value of the dissipation term at the wall assuming that u = 0 (viscous)?
I guess that at the inlet/outlet, I can simply compute the dissipation terms from the boundary values.
Any suggestions??
Thanks!
Joachim
Joachim is offline   Reply With Quote
Old   March 31, 2014, 12:20
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by Joachim View Post
Hey everyone!
Any suggestions??
Thanks!
Joachim
artificial dissipation is just a trick to stabilize the numerical solution across zones where strong gradients are present and can generate oscillations, so it should be added only locally
FMDenaro is offline   Reply With Quote
Old   March 31, 2014, 13:18
Joachim
Thanks for your answer!
However, I am using a central scheme for my convective terms (+RK order 4), so that I need fourth order artificial viscosity to remove any odd/even decoupling.
Old   March 31, 2014, 13:26
but artificial dissipation is modulated by the local gradient intensity... do you have strong gradients as BC.s?
Old   March 31, 2014, 13:32
Joachim
well, I am computing the flow over a laminar flat plate right now, so I have gradients at the wall...
Old   March 31, 2014, 13:51
This is not clear ... when you solve laminar flow, there is no unresolvable gradient in such case, therefore the artificial dissipation does not make sense...
Old   March 31, 2014, 13:54
Joachim
I have the values at time step n, and I explicitly compute the fluxes to get the state vector at time step n+1. However, I don't know if I should include the artificial viscosity at the wall or not...
How to set pulsating inlet boundary conditions with a very high frequency Ton CFX 10 March 22, 2012 16:57
Artificial Viscosity Luiz Eduardo Bittencourt Sampaio Main CFD Forum 12 November 13, 2011 10:21
The artificial farfield boundary conditions for the 2-D airfoil ljnpu Main CFD Forum 2 October 26, 2011 08:42
Immersed Boundary Ghost Cell Method thehexman Main CFD Forum 1 February 5, 2010 06:10
Boundary Conditions gaurav Main CFD Forum 3 August 6, 2003 04:04
