pressure outlet (open channel flow)
Old   April 3, 2007, 09:39
Default pressure outlet (open channel flow)
Willem Brantegem
My problem: I've got a channel (under: water, above: air). I want to give in: rate at the inlet, water height at the outlet. Fluent has to iterate till convergence. I tried: mass flow inlet: give in: water rate = ... pressure outlet: give in: free surface level = ... (using open channel flow)
My result: I've got water inflow over the whole inlet (but that's not what I want, Fluent has to calculate the water surface from the free surface at the outlet, to the inlet (by means of the rate I defined at the inlet)) And even at the outlet the water surface is not what I want. He doesn't take the free surface level that I defined.
If somebody knows a little part of the solution, or somebody knows a lot of 'open channel flow', please answer this question. My email: willem.brantegem@ugent.be
Thank you, Willem.
boundary conditions in FLUENT VOF for open channel flow newcomer Fluent Multiphase 32 May 4, 2020 07:28
Boundary condition problem for open channel flow Andy CFX 9 June 11, 2016 07:20
Open Channel Flow Boundary Conditions TWaung STAR-CCM+ 2 October 7, 2011 00:37
Reversed flow at pressure outlet Seeker Phil FLUENT 9 January 2, 2010 05:21
pressure outlet BC for incompressible flow khaiching Main CFD Forum 6 October 15, 2005 02:58
