supersonic flow over a flat plate
Old   April 5, 2007, 11:37
Default supersonic flow over a flat plate
Vishwajeet
Hello Everybody,
I am trying to simulate the supersonic flow over the flat plate from chap. 10 of Computational Fluid Dynamics by J. D. Anderson. I have written my code in f90 but my code is not working, means it is giving -ve density and pressure at outflow boundary. Can anyone provide me the correct code for this problem, because I am not able to figure out where I am making mistake.
Thank you everybody Vishwajeet vishu_iisc@yahoo.com
Old   April 15, 2007, 22:00
Default Re: supersonic flow over a flat plate
e.p.
I wrote up the 2D code based on ch. 10 of Anderson a few weeks back. Do note that the guest author who composed this chapter made several errors, the biggest of which is in eqn. 10.4d the third term should contain a tau_yy not a tau_xy.
Also make sure you are differentiating the tau and q terms opposite of the differential equation (IE, in the predictor do a reverse interpolation of d/dx, d/dy, and in the corrector do a forward interpolation of d/dx, d/dy)
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
Supersonic flow over flat plate Nikhil Main CFD Forum 6 May 20, 2013 12:48
incompressible, 2-D laminar flow over flat plate... varunjain89 Main CFD Forum 3 March 6, 2012 11:13
Supersonic flow over a flat plate and a blunt body. Maddy FLUENT 0 August 31, 2010 16:35
supersonic flow past flat plate shuo Main CFD Forum 0 July 28, 2007 19:47
