-   -   gcc and executable file from Mac to Linux (http://www.cfd-online.com/Forums/main/13275-gcc-executable-file-mac-linux.html)
simone Marras April 8, 2007 15:49
good afternoon, this is probably not the right forum, but maybe someone already encountered the same problem; I wrote a NS solver in C on my mac, and used gcc-4.0 to compile it and it compiles nirmally and generates my working executable also. When I try to generate the same exe on a Linux machine, even if it compiles without any problem, once I execute the executable output, it does not do any of the calculations. Here is my makefile in case it can help. i hope someone can help me
thanks
simone ------- makefile:
# Makefile for the code PanelMethod.c
# Varialble Definitions and Flags:
CC = gcc #Compiler is gcc LD = gcc #Linker is gcc also
CFALGS = -Wall CDEBUG = -g
# Linker flags go here. Currently there aren't any, but if we'll switch to # code optimization, we might add "-s" here to strip debug info and symbols. LDFLAGS =
# List of source codes and generated object files: SRCS = main.c nrutil.c READ_INPUT.c PRINT.c COMP_DXI_DYJ.c GRID_COORD.c wrt_f.c wrt_fvect.c INIT_FLAG.c INIT_UVP.c SETBCOND.c SETSPECBCOND.c COMP_DELT.c COMP_FG.c COMP_RHS.c NON_STAG_UV.c POISSON.c ADAP_UV.c COORDINATES.c uv_INTERPOLATION.c PARTICLE_TRACING.c COMP_PSI_ZETA.c OBJS = main.o nrutil.o READ_INPUT.o PRINT.o COMP_DXI_DYJ.o GRID_COORD.o wrt_f.o wrt_fvect.o INIT_FLAG.o INIT_UVP.o SETBCOND.o SETSPECBCOND.o COMP_DELT.o COMP_FG.o COMP_RHS.o NON_STAG_UV.o POISSON.o ADAP_UV.o COORDINATES.o uv_INTERPOLATION.o PARTICLE_TRACING.o COMP_PSI_ZETA.o
# ProgRam executable file name: EXE = out
# Top-level rule, to compile everything all: $(EXE)
# Rule to Link the program $(EXE): $(OBJS)
$(LD) $(CFLAGS) -L/usr/include -lm $(OBJS) -o $(EXE)
# Rule for the file "main.o": main.o: main.c
$(CC) $(CFLAGS) -g -I/usr/include -c main.c
# Rule for the file "nrutil.o" nrutil.o: nrutil.c nrutil.h
$(CC) $(CFLAGS) -g -I/usr/include -c nrutil.c
# Rule for the file "READ_INPUT.o" READ_INPUT.o: READ_INPUT.c READ_INPUT.h
$(CC) $(CFLAGS) -g -I/usr/include -c READ_INPUT.c
# Rule for the file "PRINT.o" PRINT.o: PRINT.c PRINT.h
$(CC) $(CFLAGS) -g -I/usr/include -c PRINT.c
# Rule for the file "COMP_DXI_DYJ.o" COMP_DXI_DYJ.o: COMP_DXI_DYJ.c COMP_DXI_DYJ.h
$(CC) $(CFLAGS) -g -I/usr/include -c COMP_DXI_DYJ.c
# Rule for the file "GRID_COORD.o" GRID_COORD.o: GRID_COORD.c GRID_COORD.h
$(CC) $(CFLAGS) -g -I/usr/include -c GRID_COORD.c
# Rule for the file "wrt_f.o" wrt_f.o: wrt_f.c wrt_f.h
$(CC) $(CFLAGS) -g -I/usr/include -c wrt_f.c
# Rule for the file "wrt_fvect.o" wrt_fvect.o: wrt_fvect.c wrt_fvect.h
$(CC) $(CFLAGS) -g -I/usr/include -c wrt_fvect.c
# Rule for the file "INIT_FLAG.o" INIT_FLAG.o: INIT_FLAG.c INIT_FLAG.h
$(CC) $(CFLAGS) -g -I/usr/include -c INIT_FLAG.c
# Rule for the file "INIT_UVP.o" INIT_UVP.o: INIT_UVP.c INIT_UVP.h
$(CC) $(CFLAGS) -g -I/usr/include -c INIT_UVP.c
# Rule for the file "SETBCOND.o" SETBCOND.o: SETBCOND.c SETBCOND.h
$(CC) $(CFLAGS) -g -I/usr/include -c SETBCOND.c
# Rule for the file "SETSPECBCOND.o" SETSPECBCOND.o: SETSPECBCOND.c SETSPECBCOND.h
$(CC) $(CFLAGS) -g -I/usr/include -c SETSPECBCOND.c
# Rule for the file "COMP_DELT.o" COMP_DELT.o: COMP_DELT.c COMP_DELT.h
$(CC) $(CFLAGS) -g -I/usr/include -c COMP_DELT.c
# Rule for the file "COMP_FG.o" COMP_FG.o: COMP_FG.c COMP_FG.h
$(CC) $(CFLAGS) -g -I/usr/include -c COMP_FG.c
# Rule for the file "COMP_RHS.o" COMP_RHS.o: COMP_RHS.c COMP_RHS.h
$(CC) $(CFLAGS) -g -I/usr/include -c COMP_RHS.c
# Rule for the file "NON_STAG_UV.o" NON_STAG_UV.o: NON_STAG_UV.c NON_STAG_UV.h
$(CC) $(CFLAGS) -g -I/usr/include -c NON_STAG_UV.c
# Rule for the file "POISSON.o" POISSON.o: POISSON.c POISSON.h
$(CC) $(CFLAGS) -g -I/usr/include -c POISSON.c
# Rule for the file "ADAP_UV.o" ADAP_UV.o: ADAP_UV.c ADAP_UV.h
$(CC) $(CFLAGS) -g -I/usr/include -c ADAP_UV.c
# Rule for the file "COORDINATES.o" COORDINATES.o: COORDINATES.c COORDINATES.h
$(CC) $(CFLAGS) -g -I/usr/include -c COORDINATES.c
# Rule for the file "uv_INTERPOLATION.o" uv_INTERPOLATION.o: uv_INTERPOLATION.c uv_INTERPOLATION.h
$(CC) $(CFLAGS) -g -I/usr/include -c uv_INTERPOLATION.c
# Rule for the file "PARTICLE_TRACING.o" PARTICLE_TRACING.o: PARTICLE_TRACING.c PARTICLE_TRACING.h
$(CC) $(CFLAGS) -g -I/usr/include -c PARTICLE_TRACING.c
# Rule for the file "COMP_PSI_ZETA.o" COMP_PSI_ZETA.o: COMP_PSI_ZETA.c COMP_PSI_ZETA.h
$(CC) $(CFLAGS) -g -I/usr/include -c COMP_PSI_ZETA.c
