GAMBIT Help
Old   April 9, 2007, 22:15
Default GAMBIT Help
asd
I have a single face with relvant node distribution. However, when i extrude this face (volume - sweep function) and cerate a mesh within this newly created volume, the node distribution is different on the upper most face. How do you maintain the same node distribution when creating a volume from an exisiting mesh. Thanks
Old   April 10, 2007, 04:27
Default Re: GAMBIT Help
Phil
don't create the volume from the meshed face but from a face without a mesh. Then create a mesh on one of the 2 faces and extrude it through the volume(cooper tool). The easiest way to do this is link the 2 faces for meshing before you mesh the first one - then it copies this mesh to the other one. This isn't always required for cooper though- only really for tri elements.
Always remember - create the geometry then make the mesh/do the boundary conditions.
hope this helps
Old   April 11, 2007, 02:43
asd
thanks heaps mate...it works! exactly what i was looking for
Thread Tools
Trackbacks are On
How to open a saved Gambit File? barkan FLUENT 5 September 1, 2012 05:53
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 09:33
between IDL Gambit and rhino, any help? philip FLUENT 0 June 23, 2005 12:08
