Fortran problem
Old   April 20, 2007, 15:21
Default Fortran problem
MM
Hi everyone, I have a fortran code with several subroutines in different .f files and an include file with all common variables. This code is in single precision. What is the easiest way to make it double precision.
Thanks MM
Old   April 20, 2007, 16:15
Default Re: Fortran problem
pc
Through compiler options (e.g., -r8). No change to code needed, assuming everything is defined as "real" and not "real*4".
If things are specifically declared single precision, you'll have to edit every routine.
Old   April 20, 2007, 20:09
Ben
i think in that case, maybe a "search n replace" should do the job, although one has to be careful.
Old   April 21, 2007, 20:03
kc
hi MM:
can you pls advise on how you compile the fortran program, in the case of you have different subroutines in different .f files??
So far, I inhclude all the subroutines (and mother program) in 1 single file, which is difficult for one to read through...
I am using the microsft visual fortran currently..
Old   April 21, 2007, 20:55
MM
Hi kc That's easy, 1)Put each sub in a different .f file. 2)Open the mother file. 3)Compile mother file 4)Go to Project/Add to project/Files 5)Select all your subroutines files and click ok
Now you have all Subs and you can run your mother file
Old   April 21, 2007, 21:00
MM
HI pc,
I didn't get you, There is no option to select in the time of compiling. Could you explain it more.
Thanks mm
Old   April 21, 2007, 21:02
MM
Hi Pc, I didn't get you, there is no option to select in time of compiling. Could you explain more.
Thanks MM
Old   April 23, 2007, 04:48
Steve
What operating system and compiler are you using. I've found the relevant switches in all the mainstream UNIX compilers, plus Absoft (for Linux) and DVF (for Windows).
Old   April 26, 2007, 13:40
pc
Nearly every Fortran compiler I've used (Linux/Unix systems) has an option to make all variables defined as "real" to be interpreted as "real*8" or "real*4" globally. It could be something like -r8 or -realsize=8, or something similar. Your compiler help should list such an option.
Thread Tools
Trackbacks are On
User fortran error when running CFX-10 in parallel CFDworker CFX 3 September 22, 2015 08:59
Fortran compiler problem Luke CD-adapco 2 September 18, 2008 03:43
Problem with Fortran installation. skarp CFX 0 August 4, 2007 07:09
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
'C' or FORTRAN or 'C++' Yogesh Talekar Main CFD Forum 20 October 21, 1999 04:00
