Simple airflow simulator?
Old   May 16, 2007, 08:15
Default Simple airflow simulator?
Wind Tinkerer
Hello all,
Is there a straightforward 2D flow simulation software out there that would let me test some ideas for a home built wind turbine?
I'm not looking for aerospace engineering software that does supersonic flows and so on. Just a flow simulator that would let me input an arbitrary shape (like a 2D airfoil section) and visualize how air would flow around it at regular wind speeds.
I've found Java applets that do this for airfoil shapes but nothing so far that lets you input an arbitrarily shaped section instead of a 'classic' airfoil shape.
If anybody knows of such a tool for Windows please point me in the right direction.
Regards,
WT
Old   May 16, 2007, 11:11
Default Re: Simple airflow simulator?
Simon Nava
You can use this website.
http://www.grc.nasa.gov/WWW/K-12/FoilSim/index.html
You can change angle of attack, camber, chord, wing span, area, etc.
I hope this helps.
Old   May 16, 2007, 11:30
Wind Tinkerer
Something like this but with the ability to simulate an arbitrary shape (not just a "wing" section).
Old   May 16, 2007, 20:57
gocarts
Have you considered a panel method? Find our more.
Old   May 17, 2007, 05:09
Wind Tinkerer
This looks interesting. Thanks. I will try it out.
Old   May 27, 2007, 17:47
Sergei Chernyshenko
Hi, WT,
Well, the engine powering the Flow Illustrator
(see http://chernyshenko.sesnet.soton.ac.uk/FIHome.htm)
is actually a full Navier-Stokes solver, and you can input an arbitrary shape, even a photograph, and get a result in a few minutes. The accuracy, however, is controlled by the image resolution, and the output is just a movie of the flow.
Anyway, you may play with it and see if it of any use for you.
Regards Sergei
Old   June 6, 2007, 17:52
Default udroi cvykdxw
gcusipf zney
dthngxsv snyeqfvw okqbviya tsnudfqlm tkynuai wjdqy jeuilg
Thread Tools
Trackbacks are On
How to add correcting pressure equation in SIMPLE of MRFSimpleFOAM? renyun0511 OpenFOAM Programming & Development 0 November 4, 2010 02:38
compressible SIMPLE method fakor Main CFD Forum 1 August 30, 2010 11:21
simple airflow through a box channel Leo Lau FLUENT 4 October 14, 2007 05:23
PISO vs. SIMPLE benedikt flurl Main CFD Forum 2 April 14, 2005 06:54
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 0 August 7, 2003 12:58
