importing airfoil geometry using icem cfd
Old   May 16, 2007, 19:06
Default importing airfoil geometry using icem cfd
ali
i'm newest in icem cfd; i would like to know how to create (import) airfoil (naca0015 for exp)geometry from data file. thank you for your collaboration.
Old   May 17, 2007, 03:19
Default Re: importing airfoil geometry using icem cfd
Charles
From the menus:
File --> Import Geometry --> Formatted point data --> Select your profile coordinates file and hit OK
The file format is just one set of space-separated x y z values per line.
This gives you the points in Icem, now you need to draw a curve through them.
Easy, no?
Old   May 19, 2007, 11:50
ali
yes it's so easy , thank you...
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
flow over an airfoil 3d ( Geometry on icem cfd ) dfmona Main CFD Forum 0 April 13, 2010 23:32
EXTRUDE option in ICEM CFD Geometry Mohammad Faridul Alam CFX 4 October 25, 2007 17:47
Importing geometry from Pro E to ICEM CFD V5.1 sac CFX 2 January 16, 2006 08:38
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
