coordinate transformation
Old   May 18, 2007, 01:22
Default coordinate transformation
Shuo
When doing calculation in the computational domain for the conservation laws (dU/dt + dF/dx + dG/dy = 0), what are the equations for transforming the flux vectors back to the physical domain(x,y)?. Also how to I attach images?
Old   May 18, 2007, 08:55
Default Re: coordinate transformation
ag
Just compute the flux vectors using their definitions - you have p, u, and rho. Or are you talking about the derivatives of the flux vectors? In that case compute the derivatives in computational space and use the metrics to transform to physical space, i.e.
d()/dx = d()/dxi*(dxi/dx) Chain rule where xi is the appropriate metric term(s).
Old   May 20, 2007, 21:09
Shuo
I mean the equation for converting flux vector F from physical to computational domain is:
F_comp = JF_phy*d(zeta)dx + JG_phy*d(zeta)/dy
So how what is the equation for vice versa? F_comp to F_phy?
Old   May 21, 2007, 08:54
ag
If you can compute the fluxes directly in the physical domain given the q-variables then why do you need it? To derive it you will need to write the flux transformation for each of the computational fluxes and then solve simultaneously. This entails inverting the the matrix composed of the metric terms. The math is not particularly difficult but is tedious. I don't know of a good reference right off the top of my head, because the inverse transformation is rarely (never) used. The physical flux vectors are directly available once the q-vector is computed.
Old   May 21, 2007, 21:02
Shuo
You mean just do all calculations in the physical domain with varying grid spaces rather than converting the fluxes onto a rectangular computational grid and then transforming them back into physical space?.
Old   May 22, 2007, 00:26
Harish
I'm assuming you are using structured grids.If not discard this note.
You can solve the system of equations in orthogonal curvilinear form or curvilinear form.In the first case the velocity components in the computational space are the transformed velocity components.But in the case of curvilinear form the velocity components are cartesian components and you transform only the derivatives
df/dx=df/dx1*dx1/dx+df/dx2*dx2/dx
Anderson et. al (computational fluid mechanics and heat transfer)discusses this point in chapter 5.
If your grid is orthogonal,use the orthogonal curvilinear form (measure the deviation of g12),if not use the general curvilinear form.
Old   May 22, 2007, 01:33
Shuo
So the values of the flux vectors when using the general coordinate system dQ/d(tau) + dF/d(zeta) + dG/d(eta) are the same in both computational and Cartesian space?
Old   May 22, 2007, 08:16
Harish
In a generalized coordinate,you do not look at them as vectors but like each is a scalar ( Ex, FX etc.)
Coordinate Transformation Problem nooredin Main CFD Forum 0 July 14, 2010 01:34
Coordinate transformation intern FLUENT 2 May 29, 2007 10:12
Coordinate Transformation Harish Main CFD Forum 0 February 9, 2006 14:04
Coordinate transformation for NS equations CFD Learner Main CFD Forum 2 June 2, 2004 18:44
cartesian to general coordinate transformation Keith Main CFD Forum 4 February 16, 2004 19:40
