May 26, 2007, 10:58 |
Effect of node size
Dear all I am the new user on Fluent program. I have a question about the effect of node size on the reliable of the simulation results, why the smaller give more reliable than the larger size. Can I find the simulation time from the simulation result file.
Thank in advance Worakij |
May 27, 2007, 19:41 |
Re: Effect of node size
I guess you mean Cell Size (Not node size) if that is correct, then you can start by searching the Wiki or your Numerical analysis book
May 27, 2007, 20:45 |
You need to figure out the meaning of convergence. According to it, as the del_x and del_t is smaller, the numerical solution become close to the exact solution. Thus, when the cell size or mesh size is relatively smaller, the solution seems close to the exact solution or goes to more accurate solution.
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
