Non dimensional code
Old   May 31, 2007, 05:38
Default Non dimensional code
Giorgos
Hello everybody.
I am writting a code for the solution of the Euler equations. Does anybody know how can I non-dimensionalise the Euler equations? (or a book describing the method)
I think there are two ways. The first is to non-domensionalise the equations and the other is to non-dimensionalise the initial conditions.
Thanks for the help
Old   May 31, 2007, 06:46
Default Re: Non dimensional code
Markus Lummer
Hello Giorgos,
you have to non-dimesionalize both, the Euler equations as well as the initial conditions. In the simplest case, you need a reference length, a reference velocity and a reference density.
Regards, Markus
Old   May 31, 2007, 08:09
Giorgos
Markus, thanks for the reply.
Do you have in mind any paper or book that explains the methodology. It is very important for me to understand in details the whole proccess
Old   May 31, 2007, 10:20
Harish
Computational Fluid mechanics and heat transfer - Anderson et. al
Old   June 1, 2007, 02:04
Shyam
The Euler code can be used as such in a non dimensionalization form. You can see many reference solutions with u=1, Rho = 1, P=1 etc. The key factor would be the ratio of specific heat.
The key factor, as mentioned by one member, is the boundary condition. See to that you adhere to the non-dimensionalized BCs and the reference scales. The rest will fall in place.
For example, ambient pressure can be 1, inlet velocity 1 etc.
Example: Reference solutions for forward facing step at Mach 3.
Regards, Shyam
Old   June 7, 2007, 02:11
p
Bird, Stewart, Lightfoot - "Transport Phenomena". towards the end of each section (Momentum/Energy/Mass Transfer), there is a kind of chapter on 'dimensional analysis of the equation of change'.
Thread Tools
Trackbacks are On
Debugging Unsteady 2-D Panel Method Code: Wake Modeling RajeshAero Main CFD Forum 5 November 10, 2011 06:48
CFD code for homework Hugo Main CFD Forum 6 April 14, 2008 16:13
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 15:56
own Code vs. commercial code Bernhard Mueck Main CFD Forum 10 February 16, 2000 11:07
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 12:44
