May 18, 2014, 06:27 |
Question about LES derivation
Stuart
Rep Power: 25 |
I was reading the CFD Wiki page about LES (http://www.cfd-online.com/Wiki/Large...tion_%28LES%29). It shows the instantaneous incompressible momentum equation and says in it is substituted in the decomposition of the velocity and pressure, so that gives: but what is the next step? The wiki page just says "filtering" but how does that look in the equation for ending up with: I cannot see the step-by-step method as the books just ignore such detail. Is it something similar (but not the same) as applying the Reynolds decomposition, time-averaging the terms and then eliminating those that are zero for RANS? A useful step-by-step guide was given for the non-dimensional NSEs at http://www.cfd-online.com/Forums/mai...er-stokes.html. Thanks |
May 18, 2014, 07:32 |
Filippo Maria Denaro
Rep Power: 71 |
First, I suggest to have a reading of some book illustrating LES (for example Sagaut).
Second, starting from the NS equation, a "filter" is formally applied on each term. If it does commute with derivatives you have d u_f/dt + Div (uu)_f + grad p_f = Div (2 mu Grad u_f) You can see that Div (uu)_f = Div (u_f u_f) + [ Div (uu)_f -Div (u_f u_f)] The last term in square brackets is the unresolved term that must be modelled The wiki page addresses an equation decomposed by using the quasi-linear form of the momentum equation but is quite simple to obtain the same procedure |
LES filtering question | martyn88 | OpenFOAM Running, Solving & CFD | 1 | October 18, 2012 03:08 |
LES supersonic flow | ziooscuro | OpenFOAM Running, Solving & CFD | 1 | March 5, 2011 00:56 |
question regarding LES | usker | Siemens | 1 | June 29, 2008 18:33 |
LES beginner question | Shuo | Main CFD Forum | 4 | July 9, 2007 08:40 |
Basic LES question | toyCFD | Main CFD Forum | 3 | August 23, 2006 15:09 |
