Mass flow rate inlet can not get accurate pressure at inlet?
Old   May 19, 2014, 06:01
Wink Mass flow rate inlet can not get accurate pressure at inlet?
Shawn
pswpswpsw is on a distinguished road
As is known to all that conservative form of equations would be considered generally better than not conservative. But, it is also pointed out in Anderson's elementary CFD textbook that one weakness of conservative form is that the following conservative boundary condition might not produce the accurate value for Pressure, Velocity, Density ,etc.
I met this problem in using a commercial CFD software named CFD-ACE by ESI-group for a steady 2D heat transfer problem without turbulence. I don't know how to deal with it.
I only have the following possible solution.
1) Increase the iteration steps
Is there anyone can tell me other possible solutions?
Thank you guys for reading my letter.
Best,
Shawn
pswpswpsw is offline   Reply With Quote
Old   May 19, 2014, 11:29
vijaymali's Avatar
Vijay Mali
vijaymali is on a distinguished road
Send a message via Skype™ to vijaymali
Hi Pan,
Fundamentally mass flow rate at inlet and static pressure at outlet should do the job. It should give you correct value of total pressure to be maintained at inlet to achieve give mass flow rate.
Sorry, I do not have experience on particular software CFD-ACE. So can't comment on that.
Could you please give more details about your CFD problem setup.
Thanks
Vijay
vijaymali is offline   Reply With Quote
Old   May 24, 2014, 06:28
Shawn
Originally Posted by vijaymali View Post
Hi Pan,
Thanks
Vijay
Hi Vijay,
Thank you for your replying. I have asked my supervisor that CFD-ACE has the problem inside and I don't need to care about it. I just need to read the value close to the boundary but not right at the boundary.
Thanks,
Shaowu
boundary condition
Thread Tools
Trackbacks are On
Mass flow rate prediction of Purge control valve using set pressure drop enr_venkat CFX 11 February 27, 2014 12:30
mass flow rate... sanjar OpenFOAM Running, Solving & CFD 1 December 2, 2013 01:09
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 12 February 11, 2010 21:28
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
Target Mass Flow Rate Nitin FLUENT 6 March 12, 2004 06:39
