basic fluid flow problem - is there a way to switch pressure to a flow rate in analyt
Old   December 4, 2010, 11:02
Default basic fluid flow problem - is there a way to switch pressure to a flow rate in analyt
vladimir nikolic
vlnikolic is on a distinguished road
hello to all
i would like to know is there a analytical equation for pressure drop for problem of fluid flow through rectangular channel
eg. i would like to prescribe Q (flow rate) instead of P (pressure) so is there a way to switch deltaP with some Q dependent formula
thank you very much
vlnikolic is offline   Reply With Quote
Old   September 15, 2016, 08:58
Jonas T. Holdeman, Jr.
Jonas Holdeman is on a distinguished road
For fully-developed flows, the flow ∆ψ and pressure gradient ∇P are known to be related by a geometry-dependent Poiseulle constant cP, n·∇P = cP ∆ψ . See: G P Galdi, An Introduction to the Mathematical Theory of the Navier-Stokes Equations, Vol. I – Linearized Steady Problems. Springer-Verlag, New York, 1994, p309.
Jonas Holdeman is offline   Reply With Quote
Old   September 15, 2016, 11:59
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by vlnikolic View Post
hello to all
thank you very much
are you talking about laminar or turbulent flow in a duct
FMDenaro is offline   Reply With Quote
Old   September 16, 2016, 04:07
just to add that for laminar incompressible steady flow, you can solve exactly the velocity field from the problem
d2w/dx^2 + d2w/dy^2 = Re*dp/dz
w=0 on the boundaries of the rectangular section
where w=w(x,y) is the stream-wise (z-direction) velocity, normal to the (x,y) plane of the rectangular section.
mass flow rate not conserved in turbomachine, interface defined wrong? wildli FLUENT 3 September 15, 2022 12:19
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
static pressure from mass flow rate SAM Main CFD Forum 4 October 27, 2004 13:15
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
