October 6, 1999, 15:49 |
A good algo for a compressible NS
Hello. I am solving the flow past n cylinders placed axis parallel. The flow is a compressible, viscous flow. Can you suggest good schemes for solving this. I will be starting with a single cylinder first. I have limited computational power.. A pentium computer with 32Mb ram. So please take that into account too.
October 7, 1999, 08:19 |
Re: A good algo for a compressible NS
I am currently solving the exact problem as part of my dissertation. Compressible viscous flow over single cylinder, both fixed and rotating. Mach number 0.5, Reynolds number 350,000 based on a diameter of 0.04m at low ambient pressure 700hPa (1013hPa is sea level).
I am using Harten's UTL1C TVD algorithm on a curvilinear grid for the inviscid part and central differences for the viscous portion of the computation. I have a Pentium processor (200Mhz) with 128MB of RAM. For a 60 by 60 mesh, the computation takes between 1 to 2 days, because of the boundary layer resolution ( delta/dia ~ Re^-0.5 ). I would give you the source code, but I am planning to turn this into a commercial software package next year. What Mach number and Reynolds number are you looking for? I may be able to run one test for you. I will send you a GIF image of one of my rotating cylinders. Your biggest task will be the grid generation for multiple cylinders. Do you have a program for that? Take care, Axel Rohde |
October 7, 1999, 11:11 |
if you have limited computational resources an explicit scheme like jameson's 4 step runge kutta scheme is appropriate. you should note that he made improvements to the scheme (the artificial dissipation) since his 1981 paper that most people reference
Compressible Boundary Condition in mid-filed | EdiVaD | FLUENT | 1 | March 7, 2011 04:52 |
easy educational compressible navier stokes implementation anywhere? | Boogiwoogie | Main CFD Forum | 0 | December 19, 2010 06:32 |
dynOneEqEddy for Compressible Flow | deji | OpenFOAM | 2 | November 17, 2010 05:57 |
Fixed grid methods for compressible viscous flow | liujmljm | Main CFD Forum | 1 | November 7, 2010 17:54 |
Compressible vs. Incompressible formulations | Fernando Velasco Hurtado | Main CFD Forum | 3 | January 7, 2000 16:51 |
