Pro-Engineer
Old   June 13, 2007, 10:56
Default Pro-Engineer
David Banks
Can you model a 3D shape in Pro-E and transfer it to Gambit? Im trying to teach myself 3D modelling by use of tutorials (which is proving difficult) and can use Pro-E. any help would be most appreciated. D
Old   June 13, 2007, 14:39
Default Re: Pro-Engineer
myron
Best bet would be to save your Pro-E part as ACIS or ParaSolid (Save a Copy or Save As) - then import that to Gambit. (I believe Gambit itself is ACIS based - so that may be the best bet.)
Old   June 14, 2007, 00:21
Tim
I have found that STEP files work the best. (Although I have never tried a parasolid out of Pro/E.)
If you save a copy as a step file and then import it to Gambit, all geometry will be real ACIS geometry.
[GAMBIT] Pro Engineer STEP import questions. f_sizer ANSYS Meshing & Geometry 10 August 2, 2010 01:17
[GAMBIT] problem in importing Pro Engineer geometry :-( arash_7444 ANSYS Meshing & Geometry 3 June 14, 2010 02:06
Prosurf to Proam problems, help please William Wallace Siemens 11 February 3, 2006 17:00
Importing geometry from Pro E to ICEM CFD V5.1 sac CFX 2 January 16, 2006 08:38
Absoft Pro Fortran 7.5 in Fluent 4.5 Thitikorn FLUENT 0 July 5, 2002 06:41
