June 14, 2007, 09:17 |
LES
Hi, if I want to save all the information about the state of a field calculated with a k-e model, I have to save the pressure, velocity k and e at each point.
Now, if I would like to take the same kind of snapshot but for a LES-calculated flow, what variables must I store ? thanks, John Deas |
June 14, 2007, 12:58 |
Re: LES
As for RANS, the number of variable to store is related to the (subgrid) model you are using. Since almost all LES models are of 0-equation kind, you should have to store the velocity components and the pressure (and density for compressible flows, ...) Regards, Lionel |
LES basic and simple questions. | dshawul | Main CFD Forum | 0 | October 4, 2010 10:56 |
Turbulence dampening due to magnetic field in LES and RAS | eelcovv | OpenFOAM | 0 | June 8, 2010 11:35 |
LES grid mesh | L3munoz | Main CFD Forum | 0 | April 7, 2010 05:05 |
LES on two phase flow | Li Yang | Main CFD Forum | 0 | May 12, 2004 08:10 |
Some Questions about LES. | Bin Li | Main CFD Forum | 2 | February 20, 2004 09:58 |
