C-grid better than O-grid in Overset for airfoil?
Old   June 25, 2007, 06:06
Default C-grid better than O-grid in Overset for airfoil?
Ben
C-grid is usually better than O-grid during simulation of airfoil's wakes due to the clustering of grids around the wake.
However, is there any advantage when the simulation is done using C + cartesian grid, as compared to O + cartesian grid?
I have already got the code working for the O + cartesian grid and I'm wondering if there's a need to change to C-grid. I need to visualise the wake and hence this is imporant to me.
Currently, there's clustering of pts along the wake for the cartesian grid.
Is there anyone which have experience in this area? Thanks
Old   June 25, 2007, 09:08
Default Re: C-grid better than O-grid in Overset for airfo
ag
Using overset you can always put a finer grid in the airfoil wake - just make sure you match grid resolutions in the overlap regions reasonably well and have enough grid points in the area where the wake enters the wake grid to resolve the initial profile. The advantage comes when you consider flows at high angles of attack - the grid cut may not be aligned at all with the direction of the wake travel. Being able to use a secondary wake grid makes it easier to capture the wake without regridding the airfoil. Of course, creating the wake grid has its own set of issues.
OVERSET grid Gino FLUENT 3 March 29, 2016 06:53
how to get the overset grid florencenawei Main CFD Forum 0 April 14, 2009 05:17
overset grid??? Dave Main CFD Forum 0 February 14, 2005 11:50
GRID TO GRID INTERPOLATION in FLUENT calogero FLUENT 3 June 4, 2003 08:32
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
