dimples/bumps on transportation vehicles
Old   August 27, 1998, 22:28
Default dimples/bumps on transportation vehicles
Gretchen Belenchia
I need help on a project that deals with the way air flows over an object with dimples or bumps as opposed to an object that is just smooth.I know pretty near nothing about fluid dynamics and would appreciate any information.
Old   August 28, 1998, 02:38
Default Re: dimples/bumps on transportation vehicles
hank
Dimples can be used to trigger boundary layer transition and thereby delay separation. For a blunt body this will give a smaller wake and often less drag due to a large low-pressure wake. A turbulent boundary layer is better than a laminar boundary layer at following a curved surface because the turbulent motions help to transport away low-velocity fluid close to the surface. This low-velocity fluid would otherwise build up and cause separation (very simple explanaition).
Evaluating CFD Packages for Hydrodynamic Drag in Underwater Vehicles Dundee Main CFD Forum 4 December 5, 2011 06:31
Job available at Bombardier Transportation braennstroem OpenFOAM 1 September 15, 2011 14:15
OF Workshop 4: External Flow on Surface Vehicles louisgag OpenFOAM 0 March 31, 2009 15:17
Micro Air Vehicles Jerry Main CFD Forum 4 November 15, 2003 03:34
Pressure-Strain Correlation/turbulent transportation Oliver Main CFD Forum 2 August 19, 1998 05:27
