-   -   NACA0012 geometry/design software needed (http://www.cfd-online.com/Forums/main/13724-naca0012-geometry-design-software-needed.html)
Franny June 26, 2007 13:04
Hi, I am looking for an accurate model of the NACA0012 airfoil compatible with Solidworks or Ansys Workbench.I am tring to build it using the coordinates but i need to have at least 50 points on the lower and 50 points on the upper surface to generate an adequate curve especially close to the leading edge and the trailing edge.I have already exported the coordinated from the NACA library,but when I import them in Solidworks it looks like the two surfaces do not join at the trailing edge.Anyone can suggest any airfoil design software available online in which i can define the number of points along the airfoil surface? Thank you.
Franny
TITAN Algorithms June 26, 2007 15:42
Re: NACA0012 geometry/design software needed
http://www.basiliscus.com/ProaSectio...xD/TableD1.txt
TITAN Algorithms June 26, 2007 15:43
sorry, I see the points don't merge here as well. Perhaps you could digitize the shape.
DSS
TITAN Algorithms June 26, 2007 16:44
I just cut an STL model of this cross section. It seems pretty accurate and the endpoints are connected. I can send it if you want.
Jonas Larsson June 26, 2007 16:46
If I remember correctly the naca 4 digit series have a certain trailing edge thickness, hence the upper and lower surfaces will not meet exactly at the trailing edge. There are variants with a zero trailing edge thickness and there are variants with a selectable thickness, but if you want the original naca 0012 geometry it will have a ceratin fixed trailing edge thickness.
Markus Lummer June 27, 2007 00:59
http://naca.central.cranfield.ac.uk/...report-460.pdf
Charles June 28, 2007 03:32
Easy way to generate airfoil coordinates for NACA 4 and 5-digit series is XFoil. You can adjust the trailing edge thickness to whatever you desire.
Franny June 28, 2007 04:40
Hi Titan Algorithms, I didnt have a chance to answer you yesterday,but it would be nice if you send the model i can have a look at it. My email address is k0433072@kingston.ac.uk I really appreciate your helo.
Franny
Franny June 28, 2007 04:44
Hi , this is why in my initial simulation,where the model used was adequate but with too few points along the surface,the pressure/coeff pressure distribution ,had a strange peak on the trailing edge! Thank you for the int! Regards Franny
TITAN Algorithms June 28, 2007 13:11
Franny
I clipped the 3D STL into one z-Segment. Hopefully it will fit here. The trailing edge is stitched up:
solid PRM NACA 0012 002
facet normal -1 0 0
outer loop
vertex 9.999871E-4 9.999863 -.1730642
vertex 9.999871E-4 10.00196 -.1731523
vertex 9.999871E-4 10.00186 -.3128053
endloop
endfacet
facet normal -1 0 0
outer loop
vertex 9.999871E-4 9.999756 -.312688
endloop
endfacet
facet normal -.9246821 .3807401 -2.91087E-4
outer loop
vertex 2.644181E-3 10.00596 -.1733195
vertex 2.644181E-3 10.00585 -.3130284
endloop
endfacet
facet normal -.9246835 .3807366 -2.912006E-4
outer loop
endloop
endfacet
facet normal -.9084393 .4180166 -3.19358E-4
outer loop
vertex 5.93245E-3 10.0131 -.1736189
vertex 5.93245E-3 10.013 -.3134275
endloop
endfacet
facet normal -.908441 .4180129 -3.195833E-4
outer loop
endloop
endfacet
facet normal -.608613 .793467 -6.057383E-4
outer loop
vertex 1.579738E-2 10.02067 -.1739358
vertex 1.579738E-2 10.02056 -.3138501
endloop
endfacet
facet normal -.608617 .7934639 -6.061936E-4
outer loop
endloop
endfacet
facet normal -.4664603 .8845419 -6.747984E-4
outer loop
vertex 2.895057E-2 10.02761 -.1742263
vertex 2.895057E-2 10.0275 -.3142374
endloop
endfacet
facet normal -.4664642 .8845398 -6.752639E-4
outer loop
endloop
endfacet
facet normal -.3580487 .9337026 -7.1181E-4
outer loop
vertex 4.703623E-2 10.03454 -.1745168
vertex 4.703623E-2 10.03443 -.3146248
endloop
endfacet
facet normal -.358052 .9337013 -7.123011E-4
outer loop
endloop
endfacet
facet normal -.2477148 .9688327 -7.38004E-4
outer loop
vertex 7.827511E-2 10.04253 -.1748514
vertex 7.827511E-2 10.04242 -.3150708
endloop
endfacet
facet normal -.2477173 .9688321 -7.38591E-4
outer loop
endloop
endfacet
facet normal -.1738432 .984773 -7.496914E-4
outer loop
vertex .1128023 10.04862 -.1751067
vertex .1128023 10.04852 -.3154112
endloop
endfacet
facet normal -.173845 .9847727 -7.501462E-4
outer loop
endloop
endfacet
facet normal -.122639 .9924511 -7.550787E-4
outer loop
vertex .1621268 10.05472 -.175362
vertex .1621268 10.05461 -.3157516
endloop
endfacet
facet normal -.1226403 .9924509 -7.555365E-4
outer loop
endloop
endfacet
facet normal -6.044437E-2 .9981713 -7.659233E-4
outer loop
vertex .2246046 10.0585 -.1755205
vertex .2246046 10.05839 -.3159629
endloop
endfacet
facet normal -.0604298 .9981722 -7.594314E-4
outer loop
endloop
endfacet
facet normal -3.065907E-2 .9995296 -7.600827E-4
outer loop
vertex .2657084 10.05976 -.1755733
vertex .2657084 10.05966 -.3160334
endloop
endfacet
facet normal -3.068257E-2 .9995289 -7.66965E-4
outer loop
endloop
endfacet
facet normal -5.548303E-3 .9999843 -7.604126E-4
outer loop
vertex .3035239 10.05997 -.1755821
vertex .3035239 10.05986 -.3160451
endloop
endfacet
facet normal -5.548362E-3 .9999843 -7.604285E-4
outer loop
endloop
endfacet
facet normal 1.161797E-2 .9999322 -7.604207E-4
outer loop
vertex .3577809 10.05934 -.1755557
vertex .3577809 10.05923 -.3160099
endloop
endfacet
facet normal 1.161809E-2 .9999322 -7.60373E-4
outer loop
endloop
endfacet
facet normal 3.797428E-2 .9992784 -7.600982E-4
outer loop
vertex .4186145 10.05703 -.1754589
vertex .4186145 10.05692 -.3158808
endloop
endfacet
facet normal 3.797468E-2 .9992784 -7.599235E-4
outer loop
endloop
endfacet
facet normal .049324 .9987825 -7.667766E-4
outer loop
vertex .4909572 10.05346 -.1753092
vertex .4909572 10.05335 -.3156812
endloop
endfacet
facet normal 4.933764E-2 .9987818 -7.597206E-4
outer loop
endloop
endfacet
facet normal 6.713503E-2 .9977436 -7.595181E-4
outer loop
vertex .5534349 10.04925 -.1751331
vertex .5534349 10.04915 -.3154465
endloop
endfacet
facet normal .0671206 .9977446 -7.659797E-4
outer loop
endloop
endfacet
facet normal .0792949 .9968509 -7.59283E-4
outer loop
vertex .6274217 10.04337 -.1748866
vertex .6274217 10.04326 -.3151178
endloop
endfacet
facet normal 7.929574E-2 .9968508 -7.588385E-4
outer loop
endloop
endfacet
facet normal 9.470211E-2 .9955054 -7.587662E-4
outer loop
vertex .6981202 10.03664 -.1746049
vertex .6981202 10.03654 -.3147422
endloop
endfacet
facet normal 9.470312E-2 .9955053 -7.582581E-4
outer loop
endloop
endfacet
facet normal .1017337 .9948114 -7.588732E-4
outer loop
vertex .7803278 10.02824 -.1742527
vertex .7803278 10.02813 -.3142726
endloop
endfacet
facet normal .1017348 .9948112 -7.582372E-4
outer loop
endloop
endfacet
facet normal .1143007 .9934459 -7.584036E-4
outer loop
vertex .8460939 10.02067 -.1739358
vertex .8460939 10.02056 -.3138501
endloop
endfacet
facet normal .1143019 .9934458 -7.578314E-4
outer loop
endloop
endfacet
facet normal .1202316 .9927456 -7.584417E-4
outer loop
vertex .9085717 10.0131 -.1736189
vertex .9085717 10.013 -.3134275
endloop
endfacet
facet normal .1202329 .9927454 -7.578689E-4
outer loop
endloop
endfacet
facet normal .1267966 .9919284 -7.583746E-4
outer loop
vertex .966117 10.00575 -.1733108
vertex .966117 10.00564 -.3130166
endloop
endfacet
facet normal .126798 .9919283 -7.578173E-4
outer loop
endloop
endfacet
facet normal .1225027 .9924679 -7.592334E-4
outer loop
vertex 1.013797 9.999863 -.1730642
vertex 1.013797 9.999756 -.312688
endloop
endfacet
facet normal .122504 .9924678 -7.58787E-4
outer loop
endloop
endfacet
facet normal -1 0 0
outer loop
vertex 9.999871E-4 10.00014 -.1730643
vertex 9.999871E-4 9.99814 -.3128053
vertex 9.999871E-4 9.99804 -.1731523
endloop
endfacet
facet normal -1 0 0
outer loop
vertex 9.999871E-4 10.00024 -.312688
endloop
endfacet
facet normal -.9249426 -.3801068 -3.009816E-4
outer loop
vertex 2.644122E-3 9.99415 -.3130284
vertex 2.644122E-3 9.99404 -.1733195
endloop
endfacet
facet normal -.9245918 -.380959 -2.7316E-4
outer loop
endloop
endfacet
facet normal -.9082876 -.4183461 -2.996341E-4
outer loop
vertex 5.93245E-3 9.987 -.3134275
vertex 5.93245E-3 9.9869 -.1736189
endloop
endfacet
facet normal -.9085231 -.4178346 -3.308557E-4
outer loop
endloop
endfacet
facet normal -.6088076 -.7933177 -6.218465E-4
outer loop
vertex 1.579735E-2 9.97944 -.3138501
vertex 1.579735E-2 9.97933 -.1739359
endloop
endfacet
facet normal -.6083273 -.793686 -5.684657E-4
outer loop
endloop
endfacet
facet normal -.4666604 -.8844363 -6.927907E-4
outer loop
vertex 2.895057E-2 9.9725 -.3142374
vertex 2.895057E-2 9.97239 -.1742263
endloop
endfacet
facet normal -.4666645 -.8844342 -6.932687E-4
outer loop
endloop
endfacet
facet normal -.3578344 -.9337847 -7.372965E-4
outer loop
vertex 4.703623E-2 9.96557 -.3146248
vertex 4.703623E-2 9.96546 -.1745168
endloop
endfacet
facet normal -.3577948 -.9337999 -7.314578E-4
outer loop
endloop
endfacet
facet normal -.2477983 -.9688114 -7.577555E-4
outer loop
vertex 7.827511E-2 9.95758 -.3150708
vertex 7.827511E-2 9.95747 -.1748514
endloop
endfacet
facet normal -.2478287 -.9688035 -7.649466E-4
outer loop
endloop
endfacet
facet normal -.173711 -.9847965 -7.028522E-4
outer loop
vertex .1128023 9.95148 -.3154112
vertex .1128023 9.95138 -.1751066
endloop
endfacet
facet normal -.1739771 -.9847494 -7.702214E-4
outer loop
endloop
endfacet
facet normal -.1227338 -.9924393 -7.752948E-4
outer loop
vertex .1621268 9.94539 -.3157516
vertex .1621268 9.94528 -.175362
endloop
endfacet
facet normal -.1225456 -.9924626 -7.083234E-4
outer loop
endloop
endfacet
facet normal -6.039882E-2 -.998174 -7.862594E-4
outer loop
vertex .2246046 9.94161 -.315963
vertex .2246046 9.9415 -.1755205
endloop
endfacet
facet normal -6.038427E-2 -.9981749 -7.797754E-4
outer loop
endloop
endfacet
facet normal -3.063586E-2 -.9995303 -7.12578E-4
outer loop
vertex .2657084 9.94034 -.3160334
vertex .2657084 9.94024 -.1755733
endloop
endfacet
facet normal -3.089115E-2 -.9995224 -7.873215E-4
outer loop
endloop
endfacet
facet normal -5.548304E-3 -.9999843 -7.807808E-4
outer loop
vertex .3035239 9.94014 -.3160451
vertex .3035239 9.94003 -.1755821
endloop
endfacet
facet normal -5.296163E-3 -.9999857 -7.129026E-4
outer loop
endloop
endfacet
facet normal 1.161798E-2 -.9999322 -7.807891E-4
outer loop
vertex .3577809 9.94077 -.3160099
vertex .3577809 9.94066 -.1755557
endloop
endfacet
facet normal .0116181 -.9999322 -7.807401E-4
outer loop
endloop
endfacet
facet normal 3.794302E-2 -.9992797 -7.804591E-4
outer loop
vertex .4186145 9.94308 -.3158808
vertex .4186145 9.94297 -.1754589
endloop
endfacet
facet normal 3.794343E-2 -.9992796 -7.802795E-4
outer loop
endloop
endfacet
facet normal .0492846 -.9987845 -7.803497E-4
outer loop
vertex .4909572 9.94665 -.3156812
vertex .4909572 9.94654 -.1753092
endloop
endfacet
facet normal 4.928514E-2 -.9987844 -7.800722E-4
outer loop
endloop
endfacet
facet normal 6.724104E-2 -.9977366 -7.052616E-4
outer loop
vertex .5534349 9.95085 -.3154465
vertex .5534349 9.95075 -.1751331
endloop
endfacet
facet normal .0670752 -.9977476 -7.795397E-4
outer loop
endloop
endfacet
facet normal 7.921845E-2 -.9968569 -7.864049E-4
outer loop
vertex .6274217 9.95674 -.3151178
vertex .6274217 9.95663 -.1748866
endloop
endfacet
facet normal 7.937218E-2 -.9968448 -7.046312E-4
outer loop
endloop
endfacet
facet normal 9.476846E-2 -.9954991 -7.113389E-4
outer loop
vertex .6981202 9.96346 -.3147422
vertex .6981202 9.96336 -.1746049
endloop
endfacet
facet normal .0946234 -.9955128 -7.853445E-4
outer loop
endloop
endfacet
facet normal .1016539 -.9948195 -7.859825E-4
outer loop
vertex .7803278 9.97187 -.3142726
vertex .7803278 9.97176 -.1742527
endloop
endfacet
facet normal .1017802 -.9948067 -7.108441E-4
outer loop
endloop
endfacet
facet normal .1143575 -.9934394 -7.787131E-4
outer loop
vertex .8460939 9.97944 -.3138501
vertex .8460939 9.97933 -.1739359
endloop
endfacet
facet normal .1143446 -.9934408 -7.848932E-4
outer loop
endloop
endfacet
facet normal .120291 -.9927384 -7.11034E-4
outer loop
vertex .9085717 9.987 -.3134275
vertex .9085717 9.9869 -.1736189
endloop
endfacet
facet normal .1201433 -.9927562 -7.781776E-4
outer loop
endloop
endfacet
facet normal .1266997 -.9919408 -7.786982E-4
outer loop
vertex .966117 9.99436 -.3130166
vertex .966117 9.99425 -.1733107
endloop
endfacet
facet normal .1268623 -.99192 -7.104478E-4
outer loop
endloop
endfacet
facet normal .1225429 -.9924629 -7.592298E-4
outer loop
vertex 1.013797 10.00024 -.312688
vertex 1.013797 10.00014 -.1730643
endloop
endfacet
facet normal .1224857 -.99247 -7.791136E-4
outer loop
endloop
endfacet endsolid
saygin June 29, 2007 03:28
This is NACA0012 data that I extracted from MeshPilot program -i guess the program was that, it was some long time ago-. The trailing edge has no thichness. Hope it helps.
Saygin
0.100000000000000E+01 0.000000000000000E+00
0.999614518000000E+00 -0.544672999000000E-04
0.998458667000000E+00 -0.217631273000000E-03
0.996534228000000E+00 -0.488780719000000E-03
0.993844170000000E+00 -0.866738829000000E-03
0.990392640000000E+00 -0.134987575000000E-02
0.986184960000000E+00 -0.193612572000000E-02
0.981227618000000E+00 -0.262300840000000E-02
0.975528258000000E+00 -0.340765371000000E-02
0.969095668000000E+00 -0.428682981000000E-02
0.961939766000000E+00 -0.525697329000000E-02
0.954071587000000E+00 -0.631422093000000E-02
0.945503262000000E+00 -0.745444229000000E-02
0.936248004000000E+00 -0.867327229000000E-02
0.926320082000000E+00 -0.996614304000000E-02
0.915734806000000E+00 -0.113283142000000E-01
0.904508497000000E+00 -0.127549011000000E-01
0.892658465000000E+00 -0.142409002000000E-01
0.880202983000000E+00 -0.157812112000000E-01
0.867161255000000E+00 -0.173706557000000E-01
0.853553391000000E+00 -0.190039913000000E-01
0.839400373000000E+00 -0.206759225000000E-01
0.824724024000000E+00 -0.223811065000000E-01
0.809546975000000E+00 -0.241141560000000E-01
0.793892626000000E+00 -0.258696373000000E-01
0.777785117000000E+00 -0.276420659000000E-01
0.761249282000000E+00 -0.294258983000000E-01
0.744310621000000E+00 -0.312155228000000E-01
0.726995250000000E+00 -0.330052474000000E-01
0.709329869000000E+00 -0.347892879000000E-01
0.691341716000000E+00 -0.365617557000000E-01
0.673058529000000E+00 -0.383166466000000E-01
0.654508497000000E+00 -0.400478310000000E-01
0.635720225000000E+00 -0.417490475000000E-01
0.616722682000000E+00 -0.434138991000000E-01
0.597545161000000E+00 -0.450358538000000E-01
0.578217233000000E+00 -0.466082501000000E-01
0.558768699000000E+00 -0.481243080000000E-01
0.539229548000000E+00 -0.495771448000000E-01
0.519629908000000E+00 -0.509597976000000E-01
0.500000000000000E+00 -0.522652520000000E-01
0.480370092000000E+00 -0.534864757000000E-01
0.460770452000000E+00 -0.546164591000000E-01
0.441231301000000E+00 -0.556482599000000E-01
0.421782767000000E+00 -0.565750537000000E-01
0.402454839000000E+00 -0.573901875000000E-01
0.383277318000000E+00 -0.580872372000000E-01
0.364279775000000E+00 -0.586600665000000E-01
0.345491503000000E+00 -0.591028872000000E-01
0.326941471000000E+00 -0.594103194000000E-01
0.308658284000000E+00 -0.595774500000000E-01
0.290670131000000E+00 -0.595998890000000E-01
0.273004750000000E+00 -0.594738214000000E-01
0.255689379000000E+00 -0.591960541000000E-01
0.238750718000000E+00 -0.587640567000000E-01
0.222214883000000E+00 -0.581759944000000E-01
0.206107374000000E+00 -0.574307527000000E-01
0.190453025000000E+00 -0.565279534000000E-01
0.175275976000000E+00 -0.554679596000000E-01
0.160599627000000E+00 -0.542518714000000E-01
0.146446609000000E+00 -0.528815102000000E-01
0.132838745000000E+00 -0.513593929000000E-01
0.119797017000000E+00 -0.496886949000000E-01
0.107341535000000E+00 -0.478732030000000E-01
0.954915028000000E-01 -0.459172594000000E-01
0.842651938000000E-01 -0.438256957000000E-01
0.736799178000000E-01 -0.416037600000000E-01
0.637519965000000E-01 -0.392570363000000E-01
0.544967379000000E-01 -0.367913599000000E-01
0.459284131000000E-01 -0.342127270000000E-01
0.380602337000000E-01 -0.315272039000000E-01
0.309043320000000E-01 -0.287408335000000E-01
0.244717419000000E-01 -0.258595439000000E-01
0.187723818000000E-01 -0.228890595000000E-01
0.138150398000000E-01 -0.198348152000000E-01
0.960735980000000E-02 -0.167018778000000E-01
0.615582970000000E-02 -0.134948731000000E-01
0.346577152000000E-02 -0.102179230000000E-01
0.154133313000000E-02 -0.687459120000000E-02
0.385481880000000E-03 -0.346784024000000E-02
0.000000000000000E+00 0.000000000000000E+00
0.385481880000000E-03 0.346784024000000E-02
0.154133313000000E-02 0.687459120000000E-02
0.346577152000000E-02 0.102179230000000E-01
0.615582970000000E-02 0.134948731000000E-01
0.960735980000000E-02 0.167018778000000E-01
0.138150398000000E-01 0.198348152000000E-01
0.187723818000000E-01 0.228890595000000E-01
0.244717419000000E-01 0.258595439000000E-01
0.309043320000000E-01 0.287408335000000E-01
0.380602337000000E-01 0.315272039000000E-01
0.459284131000000E-01 0.342127270000000E-01
0.544967379000000E-01 0.367913599000000E-01
0.637519965000000E-01 0.392570363000000E-01
0.736799178000000E-01 0.416037600000000E-01
0.842651938000000E-01 0.438256957000000E-01
0.954915028000000E-01 0.459172594000000E-01
0.107341535000000E+00 0.478732030000000E-01
0.119797017000000E+00 0.496886949000000E-01
0.132838745000000E+00 0.513593929000000E-01
0.146446609000000E+00 0.528815102000000E-01
0.160599627000000E+00 0.542518714000000E-01
0.175275976000000E+00 0.554679596000000E-01
0.190453025000000E+00 0.565279534000000E-01
0.206107374000000E+00 0.574307527000000E-01
0.222214883000000E+00 0.581759944000000E-01
0.238750718000000E+00 0.587640567000000E-01
0.255689379000000E+00 0.591960541000000E-01
0.273004750000000E+00 0.594738214000000E-01
0.290670131000000E+00 0.595998890000000E-01
0.308658284000000E+00 0.595774500000000E-01
0.326941471000000E+00 0.594103194000000E-01
0.345491503000000E+00 0.591028872000000E-01
0.364279775000000E+00 0.586600665000000E-01
0.383277318000000E+00 0.580872372000000E-01
0.402454839000000E+00 0.573901875000000E-01
0.421782767000000E+00 0.565750537000000E-01
0.441231301000000E+00 0.556482599000000E-01
0.460770452000000E+00 0.546164591000000E-01
0.480370092000000E+00 0.534864757000000E-01
0.500000000000000E+00 0.522652520000000E-01
0.519629908000000E+00 0.509597976000000E-01
0.539229548000000E+00 0.495771448000000E-01
0.558768699000000E+00 0.481243080000000E-01
0.578217233000000E+00 0.466082501000000E-01
0.597545161000000E+00 0.450358538000000E-01
0.616722682000000E+00 0.434138991000000E-01
0.635720225000000E+00 0.417490475000000E-01
0.654508497000000E+00 0.400478310000000E-01
0.673058529000000E+00 0.383166466000000E-01
0.691341716000000E+00 0.365617557000000E-01
0.709329869000000E+00 0.347892879000000E-01
0.726995250000000E+00 0.330052474000000E-01
0.744310621000000E+00 0.312155228000000E-01
0.761249282000000E+00 0.294258983000000E-01
0.777785117000000E+00 0.276420659000000E-01
0.793892626000000E+00 0.258696373000000E-01
0.809546975000000E+00 0.241141560000000E-01
0.824724024000000E+00 0.223811065000000E-01
0.839400373000000E+00 0.206759225000000E-01
0.853553391000000E+00 0.190039913000000E-01
0.867161255000000E+00 0.173706557000000E-01
0.880202983000000E+00 0.157812112000000E-01
0.892658465000000E+00 0.142409002000000E-01
0.904508497000000E+00 0.127549011000000E-01
0.915734806000000E+00 0.113283142000000E-01
0.926320082000000E+00 0.996614304000000E-02
0.936248004000000E+00 0.867327229000000E-02
0.945503262000000E+00 0.745444229000000E-02
0.954071587000000E+00 0.631422093000000E-02
0.961939766000000E+00 0.525697329000000E-02
0.969095668000000E+00 0.428682981000000E-02
0.975528258000000E+00 0.340765371000000E-02
0.981227618000000E+00 0.262300840000000E-02
0.986184960000000E+00 0.193612572000000E-02
0.990392640000000E+00 0.134987575000000E-02
0.993844170000000E+00 0.866738829000000E-03
0.996534228000000E+00 0.488780719000000E-03
0.998458667000000E+00 0.217631273000000E-03
0.999614518000000E+00 0.544672999000000E-04
Franny June 30, 2007 04:43
Thank you very much Saygin.I ve build it up the airfoil in solidworks and i will use it to simulate the flow in CFX.It looks a lot better of the one I had as is defined by much more points. Thanks again.
Franny
Franny June 30, 2007 04:46
Hi, thank you very much for your help.I will try to use your coordinates. Very kind of you.
Thank you again.
Franny
John Chawner July 7, 2007 15:57
Here are two more options.
UIUC Airfoil Coordinates Database:
http://www.ae.uiuc.edu/m-selig/ads/c...atabase.html#N
DesignFOIL software:
http://www.dreesecode.com/
