-   -   I want to know how to find out the latex in redhat (http://www.cfd-online.com/Forums/main/13730-i-want-know-how-find-out-latex-redhat.html)
KK June 28, 2007 01:51
Dear friends, i installed redhat linux on my PC, i want to use latex software,, i want to know how to find it,, in suse i used but not in redhat,, i cant able to find it,, could some one help me please kk
jinwon June 28, 2007 08:13
Re: I want to know how to find out the latex in re
I am using ubuntu. In ubuntu, I am using lyx, texeditor, etc. The best one is lyx which is a very friendly GUI. As far as I know, you can download the lyx and texeditor from their contributor by rpm or tar.gz format
g June 28, 2007 08:32
Just use rpm.
Mani June 28, 2007 08:53
Latex is included in every RedHat (and Fedora) version I have seen so far. When you install Linux (any dist), always use "custom installation" that let's you hand-pick the packages you want to install. Since you're already done with the installation there are various ways to add software packages. If you don't know much about it, the easiest and safest way may be to "update" your installation, using the same CD's/DVD's you used to install it, and this time make sure that Latex is included.
OPS July 5, 2007 04:00
Do the following:
1. Open 'gvim' or any other tex editor. 2. Write whatever you want to right. Save as filename.tex extention. 3. Open a terminal, go to the directory where you have stored filename.tex
4. Type "latex filename.tex" and enter.
5. This will create a .dvi file. You can convert in into .ps or pdf files.
Best wishes.
