How to set the grid for turbulent-boundary flow
Old   July 18, 2007, 08:36
Default How to set the grid for turbulent-boundary flow
xumustc
How to set the grid for turbulent-boundary flow As many books and papers said, for the turbulent-boundary flow, The distance from the wall to the first cell center is set to satisfyat least y+ &le; 2, and there are approximately20â€"30 gridpoints within y+ < 100. (Ubaldo Cella, Arthur Rizzi. Sensitivity to Physical and Numerical Modeling in Navier-Stokes Simulations ) or
0.1&le; y+&le;0.5 for low Reynolds number model, 0.5&le; y+&le;1.0 for high Reynolds number model. (Tuncer ,Cebeci. Turbulence models and their application : efficient numerical methods with computer programs.) I have a question : Before the calculation, how can we get &tau;W for y+,since y+= y(&tau;W/&rho0.5/&nu;? especially for compressible flow, &rho;,&nu;in y+= y(&tau;W/&rho^0.5/&nu; can't be taken as&rho;&infin;,&nu;&infin;,what hell can I do?
Old   July 20, 2007, 11:56
Default Re: How to set the grid for turbulent-boundary flo
NewtonUSP
Usually, u should try some coarse mesh first and then try to refine the places where it needs. It also depends on the turbulence model you are using and the variables you want to get. You see, for a wing simulation, for some turbulence models you need to refine the mesh in the shear layer to obtain the aerodynamic coefficients. For other models, u should not to refine this region, because it may use some wall treatment. I hope it helps...
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
non reflective boundary conditions for incompresible flow Pascal_doran OpenFOAM Programming & Development 16 August 25, 2015 05:35
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 02:53
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
