Spalart-Allmaras turbulent model
Old   July 24, 2007, 20:41
Default Spalart-Allmaras turbulent model
Mohamed
Hi All,
I had coded Spalart-Allmaras turbulent model by using finite volume, pseudo time and LUSGS on Unstructred grid. When trying to validate it againest flat plate (Stanford case 1400), I found that the turbulent viscosity always decreasing. Does any one had experince with such problem. your suggestions is more than welcome.
Old   July 27, 2007, 08:15
Default Re: Spalart-Allmaras turbulent model
Lionel S.
What is the Reynolds number, or incident velocity ?
I think that S-A turb model is good only for high Reynolds number applications, especially aerodynamics. For general purposes, I would advice using a very standard k-epsilon model.
Old   July 30, 2007, 00:59
Mohamed
Thanks alot Lionel for your reply, Re = 4.4e6 velocity = 33 m/s,
About your advice using k-epsilon model, I already coded S_A model and I thank K-epsilon model is much more complicated especially for unstructured grid. Also K-epsilon has its problems. So that, I want to compromise between numerical complexity and numerical efficiecny.
Thread Tools
Trackbacks are On
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
nut wall function for Spalart Allmaras model wei_wu OpenFOAM Programming & Development 0 February 9, 2010 17:30
Numerical integration of Spalart Allmaras turbulence model RenardP Main CFD Forum 0 June 11, 2009 14:53
Spalart Allmaras model Muhammad Shakaib Main CFD Forum 1 August 3, 2006 08:57
