2D Riemann analytic solution.
Old   July 28, 2007, 17:55
Default 2D Riemann analytic solution.
jinwon park
I am solving a two-fluid flow both in 1D and in 2D. In 1D, the constant states across the material interface are aligned normally. But in 2D, the application of the normal-to-interface is not trivial applied. So I am using the level set method to treat it by the normal-to-interface logic. Although it seems the normal-to-interface, the Riemann solution across the material interface was not applicable. Have you ever experienced this kind of case?
Please anyone teach me how to use the Riemann analytic solution in 2D. That is, the condition in the star region was usually taken by the cartesian 1D Riemann analytic solution then I tried to apply these values across the material interface in 2D.
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 21:22
two-phase Riemann analytic solution or solver. jinwon Main CFD Forum 0 July 12, 2007 22:09
Unsteady solution Christophe FLUENT 0 August 11, 2006 11:13
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
