multistep Adams Bashforth schemes
Old   August 7, 2007, 12:42
Default multistep Adams Bashforth schemes
suresh
Hi
I am trying to use two different time steps on different parts of the same grid (dense and coarse) to redurce the run time. I am using the adams bashforth time marching scheme to do it. It works fine but there are small errors introduced in the solution for a high frequence gust on an airfoil test case. does any body have any suggesstion about how to do this efficiently.
Thanks in advance
Old   August 8, 2007, 13:34
Default Re: multistep Adams Bashforth schemes
Harish
You need to be more specific about the schemes you use and how you match the two grid regions.The grid interfaces can give rise to parasite waves which might introduce oscillations in the solution,if not properly handled.
time stepping schemes for compressible DNS/LES shyamdsundar Main CFD Forum 0 January 14, 2010 23:15
Adams Bashforth time intergation mnabi Main CFD Forum 0 June 25, 2009 10:24
Runge Kutta vs adams bashforth time marching vasanth Main CFD Forum 5 January 1, 2006 00:17
Adams Bashforth schemes vasanth Main CFD Forum 1 December 23, 2003 01:56
Higher-order bounded convection schemes for pure advection with discontinuity Anthony Main CFD Forum 3 June 13, 1999 02:36
