Grid resolution - Segmentation fault
Old   September 4, 2007, 17:38
Default Grid resolution - Segmentation fault
George
Hello everyone,
I am getting a Segmentation Fault when I am trying to run my code with a grid resolution of 256x256x256 grid points under the MPI environment. However, the code works fine if a grid of 256x256x512 points is used.
Any help regarding this will be most appreciated.
Thanks.
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 21:59
ParaView segmentation fault only for multiphase gwierink OpenFOAM 9 March 25, 2010 07:23
Do high grid resolution capture accurate shocks? Explicit someone Main CFD Forum 1 November 10, 2008 05:48
Large difference in grid resolution for diff paper Ben Main CFD Forum 16 April 7, 2007 11:45
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
