Engineering report
Old   October 11, 1999, 21:22
Default Engineering report
Susan
Hi, I go to Maritime College and I am a ME major. I need some definitions for a report and I can't find them anywhere. Can you help me, please? The definitions that I'm looking for are: Dimensionless Parameters, Basic Dimensions, Buckingham (3.14...) Theorem, Pressure Coefficient (Cp), Geometric Variables, Kinematic Variables, Dynamic Variables, Sheer Stress (or Drag) Coefficient, Darcy-Weisbach Equation, Resistance Coefficient. All these having to do with my Engineering 243, Transport Processing (fluids) class. I thank you for any help you can give.
Old   October 12, 1999, 12:34
Default Re: Engineering report
John C. Chien
(1). Can't find them anywhere? You can find almost anything on Internet. (2). Get on Yahoo or the like, then type the key words you are looking for. Then you should be able to find everything related to it. (3). Internet is bigger than a book, or a library.
Old   October 12, 1999, 14:26
Rainer Kurz
The definitions can be found in almost any text book on fluid mechanics. The exception may be Darcy-Weisbach, which is an equation to calculate the friction factor for pressure losses in pipes.
Old   October 12, 1999, 20:25
Ali Habibi
Hi I looked at "Mechanic of fluids"(Irving H. Shames 1982) you can find what you looking for in chap.1,2,7,8.
Old   October 13, 1999, 14:08
clifford bradford
i find it strange that you fluid mechanics book does not have some or all of these definitions/formulas. you can try "Fundamentals of Fluid Mechanics" by Munson, Young and Okiishi the library of congress call number is TA357.M86
things like this are best found in textbooks and not on the web.
cfd report naor Main CFD Forum 0 October 29, 2010 12:55
Report > Discrete Phase > Report > How to commands Francesco Micchetti FLUENT 1 January 23, 2008 06:10
CCL report needed very much lq3088066 Main CFD Forum 0 February 16, 2005 04:39
Can U find this Solution Report N°229 Mohamed FLUENT 5 June 19, 2003 03:28
How to obtain AWRE tech report (Youngs)? Zi-Wei Chiou Main CFD Forum 2 October 4, 2001 11:09
