Confusion abt non-uniform staggered grid
Old   August 20, 2007, 07:49
Default Confusion abt non-uniform staggered grid
CF
I'm trying to write a code using SIMPLE on staggered cartesian grids. The books I read mention that u,v,p each are solved on their control volume.
However, all the examples are given on uniform grids. What if the grid are non-uniform?
If the p nodes are defined on the center of its control volume, is it correct to say that the u nodes will be on the left, right faces of the p control volume?
In that case, is the left,right faces of the u control volume on the same location as the p nodes? But if that's the case, u will not be in the center of its own control volume.
Or the p nodes do not coincide with the left, right faces of the u control volume and u is at the center of its own control volume.
Which one is correct? Or can both be used? Is there any preferred choice? Thank you.
Old   August 21, 2007, 08:14
Default Re: Confusion abt non-uniform staggered grid
student
the type of scheme you apply is important. and you have to use weighted interpolation.
Old   August 29, 2007, 04:46
p
for a 1d problem let's say, two adjacent p control volumes will have lengths delta_x_1 and delta_x_2. the u control volume will thus have length 1/2(delta_x_1 + delta_x_2). is that the confusion? in the program have one delta_x array and subsequently when the delta_x of p cv is required, use that starightway. when the delta_x of the u cv is required, go by the algebra as above. remember delta_x_1/delta_x_2 ratio (larger/smaller) should not exeed 1.2 or so, if delta_x_1 is larger.
Thread Tools
Trackbacks are On
Free jet simulation msarkar OpenFOAM Running, Solving & CFD 34 November 3, 2015 11:12
chtMultiRegionSimpleFoam javad814 OpenFOAM 1 September 26, 2011 13:30
Need help with boundary conditions: open to atmosphere Wolle OpenFOAM 2 April 11, 2011 07:32
rhoSimpleFoam claco OpenFOAM 7 April 20, 2010 04:32
RasInterFoam STRANGE RESULTS AT BOUNDARY kumar2 OpenFOAM Running, Solving & CFD 8 March 24, 2008 19:38
