Einestine summation - help
Old   August 23, 2007, 06:11
Default Einestine summation - help
taw
Can someone explain to me which one of this is right for;
d(u_i u_i)/dt = nu(d(u_i)/d(x_j))^2
for x - momentum
is it
A. d(u_1)^2/dt = nu(d(u_1)/d(x_1) + d(u_1)/d(x_2))^2
or
B. d(u_1)^2/dt = nu(d(u_1)/d(x_1))^2 + (d(u_1)/d(x_2))^2.
I am really confused, please help.
With regards,
Tilek
Old   August 23, 2007, 08:45
Default Re: Einstein summation - help
JWilliams
With Einstein Summation, you will only sum over the repeated index (indices), (i.e. 'i' in this case)
For X-momentum (j=1) you would sum the i's (i=1,2,3)
But since this sounds like a homework assignment I won't put up the answer just yet.
Old   August 23, 2007, 21:14
Default Re: Einestine summation - help
taw
Yeah thanks for the comment and I still look forward to your feedback.
A colleague here said it is (A). But I saw esp. the RHS to be possibly written as nu(d(u_i)/d(x_j))(d(u_i)/d(x_j)) in which case (B) looks the case applicable here. In my first thought also; if I have to write it in code (like Fortran), with a do loop, it sounds to be case (B). But in the line of the rule "sum first the repeated indices", it would look case (A) applies. I think this is a simple problem for those in turbulence research, which I am struggling right now. I appreciate feedback still.
Cheers, TAW
Old   August 24, 2007, 08:47
JWilliams
Well for strictly ESN (Einstein Summation Notation), both are wrong. You will not sum the J's, since it is not a repeated index, so leave the J as is.
And if you want just i=1, just substitute in. This isn't really ESN if you just want i=1.
Span-wise summation of Fluent 3D data ayannath23 FLUENT 2 May 26, 2011 16:36
How to control the time step and iteration for summation? josh_z Fluent UDF and Scheme Programming 2 February 23, 2010 10:02
How to get cumulative summation of one field lin OpenFOAM Running, Solving & CFD 7 May 17, 2009 09:52
Einstein's summation convention Lionel S. Main CFD Forum 2 February 23, 2007 15:28
How to get summation of one variable at x directio zhou1 FLUENT 3 October 21, 2003 10:17
