Tee mixer
Old   August 31, 2007, 05:12
Default Tee mixer
Kasper
Hi Experts,
I'm currently looking at tee mixers. That is a jet inlet entering a main stream from the side (90 degrees specific).
In my case the purpose is to mix hot gas with cold fresh air. Say 400C with 50C (Africa for instance). The dimensions could be 5000mm main stream pipe diameter and 2000mm diameter fresh air inlet pipe.
I wan't to find some litterature on the subject. Does anyone have some papers or links to pages on this subject?
Thank you in advance
Kasper Skriver, Denmark
Old   August 31, 2007, 11:43
Default Re: Tee mixer
agg
The following reference talks about tee mixers.
Forney, L.J., Nafia, N. and Vo, H.X. (1996). Optimum jet injection in a tubular reactor. AIChE Journal, 42 (11), 3113-3122.
Kenics mixer fluent setup ankur gupta FLUENT 0 August 12, 2010 07:34
Simulating a static mixer in Fluent Novice FLUENT 1 January 26, 2009 13:09
Fluid Dynamics tee shirts Jack McInerney Main CFD Forum 0 March 29, 2008 09:03
Fluid Dynamics Eng - PAX Mixer - San Rafael, CA Gary Jong FLUENT 0 February 25, 2008 20:46
Venturi Mixer Formula & Equations Gen Woo Main CFD Forum 2 December 11, 2006 18:32
