Fluid-structure interaction using the Riemann solv
Old   August 28, 2007, 12:59
Default Fluid-structure interaction using the Riemann solv
jinwon park
I wonder if anyone know the way to use the Riemann analytic solver(exact) for the fluid-structure interaction.
Most books just explain the way to construct the Riemann solver, not any reflection from the solid wall or the elastic wall. Is there anyway to use the Riemann analytic solver for the fluid-structure interactoin?
Thanks in advance!
Old   August 28, 2007, 15:36
Default Re: Fluid-structure interaction using the Riemann
ag
Unless you are trying to tightly couple the equations for the fluid and structure together, a Riemann solver is used just like any other algorithm in CFD - solve the fluid equations using the Riemann solver-based algorithm, transfer the surface traction to the structural nodes using some type of coupling software, solve the structural response, transfer displacements and velocities to the fluid nodes, update the fluid response, repeat ad infinitum or convergence. This is how most FSI codes are put together (at least the ones I am familiar with.)
Old   August 28, 2007, 15:38
jinwon park
Thanks a lot
Old   September 5, 2007, 06:19
abouziar
I use exact Riemann solver for FSI but I use high order Godunov type methods in Euler variables for both (for fluids-Euler eq. with Tate state eq. and for structures - Euler-Couchi eq. with Hook's law, plasticity and etc. are taken into account for CSD on the corrector step(splitting)), on the contact of course Lagrang, it works stable for explosions and for impact problem with velocities up to 20km/sec. for Tue: before changing CFD also for CSD (it is not so complicated) I used Godunov type (FVM) for fluids and Wilkins for structures, coupling was as Tue wrote, it was not stable for acoustic case, but for force estimation at the beginning of the construction loading it was OK.
Fluid structure interaction on baloons vinz OpenFOAM Running, Solving & CFD 38 September 14, 2016 12:38
Fluid structure interaction with ANSYS-CFX Amol CFX 3 November 29, 2015 08:36
Fluid Structure Interaction shaan Main CFD Forum 1 February 20, 2012 13:26
Fluid structure interaction in ANSYS-CFX Amol CFX 4 April 4, 2011 12:18
Fluid structure interaction in Fluent Hari Prasad FLUENT 2 July 16, 2010 03:17
