weakly compressible vs Artificial compressible system? |
August 31, 2014, 16:25 |
Vino
Rep Power: 13 |
hi,
is there any difference between Weakly compressible vs Artificial compressibility methods? Thanks. |
September 4, 2014, 02:14 |
#2 | |
Michael Prinkey
Rep Power: 25 |
Artificial compressibility methods work in roughly the opposite way. They start as fully compressible, often density-based and/or explicit methods, and attempt to model incompressible flow by artificially tweaking the Mach number to balance stability constraints versus the introduction of spurious compressibility. So, the former is generally an incompressible scheme tweaked to admit some weak compressibility. The latter is generally a compressible scheme tweaked to approximately model incompressible flow. |
September 4, 2014, 03:30 |
Vino
Rep Power: 13 |
Thanks Michael Prinkey.!This is what i understood.
Incompressible flow algorithms are used for compressible flow through weakly compressible method. Compressible flow algorithms are used for incompressible flows through Artificial compressibility method. |
Artificial Viscosity | Luiz Eduardo Bittencourt Sampaio | Main CFD Forum | 12 | November 13, 2011 10:21 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Compressible -> incompressible. | Jinwon | Main CFD Forum | 6 | November 23, 2007 21:07 |
Need ideas-fuel discharge system | Jan | CFX | 1 | October 9, 2006 08:16 |
Need ideas-fuel discharge system | Jan | Main CFD Forum | 0 | October 9, 2006 04:27 |
