hot points, heterogeneity
Old   August 25, 2007, 06:21
Default hot points, heterogeneity
sylvain
I have a problem resolving energy and radiation on a reactor with a symmetry, I obtain two hot points ( some cells have a temperature 500° higher than its neighboors) on the symmetry surface and I can't make them disappear : what can I do? What is the problem? When I don't use a symmetry, i have no problem.
Old   August 27, 2007, 08:34
Default Re: hot points, heterogeneity
sylvain
i tried a coarser mesh and seems to solve the problem, is there any explanation?
Thanks
Old   September 17, 2007, 06:53
Rami
How did you model symmetry? For radiation, this should be done by making the symmerty surfaces perfect specular reflectors (i.e., prefect mirrors).
Old   September 17, 2007, 08:51
sylvain
where do I have to choose this type?
thanks for your contribution
Old   September 17, 2007, 09:26
Rami
Not sure what you ask here. Are you referring to some specific (commercial or not) code? My former post is general. How to apply it to a certain code (if at all possible) is another issue.
Old   September 19, 2007, 02:59
sylvain
Yes in fact i am using fluent, maybe i should have said it earlier...
Old   September 19, 2007, 03:41
Rami
sylvain,
I suggest that you post queries relevant to Fluent on the Fluent forum.
According to Fluent documentation, specular surfaces are only treated with the DO (Discrete Ordinate) radiation model (unfortunately). Hence, symmetric BC may be treated only with this model.
Sliding Interface issues philippose OpenFOAM Running, Solving & CFD 7 May 5, 2014 03:13
[snappyHexMesh] jagged, ragged edges... ziemowitzima OpenFOAM Meshing & Mesh Conversion 138 July 23, 2012 23:41
Gauss Quadrature points dhruv OpenFOAM 4 September 26, 2011 04:59
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
extreme points problem Lipo Wang Main CFD Forum 2 August 18, 2004 03:15
