Difference between laminar and turbulent separatio |
September 20, 2007, 07:43 |
What is the difference between laminar (LS) and turbulent separation (TS) for a flow over circular cylinder?
September 20, 2007, 09:00 |
Re: Difference between laminar and turbulent separ
If it's any help try Dimples on Golf Balls for an explanation of laminar and turbulent boundary layer separation over a sphere - I think you'll find the reasoning similar to the flow over a cylinder.
September 20, 2007, 12:50 |
What difference do you want to know about?
The turbulent one will have a smaller wake, this is why skaters use strips on their arms (streamlined shapes like cycling helmets are not allowed for them). |
September 21, 2007, 05:06 |
Thanks. In one paper by Trevin et. al, he talks about LS (laminar separation) and TS (turbulent separation) at Re=140000. How can we get laminar or turbulent separation using the same code?
September 21, 2007, 05:25 |
First of all, I suppose your code is 2D.
Does it have a transition model? |
September 21, 2007, 07:28 |
My code is 3D DES using S-A turbulence model.
September 21, 2007, 07:41 |
Ooh, isn't that a bit heavy for cylinder flow? Why don't you use a 2D solver? You run in fully turbulent then I suppose?
Anyway, if you only want to see the difference in the wake for engineering purposes, I think it's tabulated somewhere, maybe in the drag book by Hoerner. |
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 07:08 |
Laminar vs Turbulent Navier-Stokes | truman | Main CFD Forum | 8 | July 10, 2017 07:20 |
Laminar doesn't converge; Turbulent models do? | Amit | FLUENT | 11 | April 23, 2015 22:55 |
SimpleFoam: Laminar vs. Turbulent Convergence | JasonG | OpenFOAM | 0 | June 2, 2011 08:29 |
difference of the laminar and turbulent model | duaiduaihu | FLUENT | 0 | August 13, 2010 23:40 |
