September 26, 2007, 23:16 |
convergence
What should we do if 2 out of 10 CFD models do not converge? We need to compare CFD results amongst all 10 cases but 2 of them not converged. If we change under-relaxation factors for 2 of these, will our comparison be valid? What do people normally do when encounter this problem?
September 28, 2007, 08:08 |
Re: convergence
Your final result should not depend on relaxation factor. For rectifying convergence problem, have look on the poorley formed / diverged solution, and try to find regions of unrealistic numerical values of physical parameters, for your case of application. That can give you an idea for reason of divergence.
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 09:48 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
Defect correction and convergence | ganesh | Main CFD Forum | 4 | June 30, 2006 14:20 |
