Finite Difference Methods in CFD
Like Tree1Likes
  • 1 Post By flotus1
Old   September 20, 2014, 12:19
Default Finite Difference Methods in CFD
British Columbia
Warda is on a distinguished road
Hello every one,
I am new CFD student and I need you help to solve this problem
Warda is offline   Reply With Quote
Old   September 20, 2014, 13:10
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
So what exactly is your question?
flotus1 is offline   Reply With Quote
Old   September 20, 2014, 14:11
British Columbia
I need help to write the second order finite difference discretiation and to find f . thank you
Old   September 20, 2014, 16:50
flotus1's Avatar
Alex
I guess you mean -\nabla^2 u = f
In two-dimensional cartesian coordinates (x and y) this unfolds to
-\frac{\partial^2 u}{\partial x^2} -\frac{\partial^2 u}{\partial y^2} = f
The derivatives can now be replaced with some finite difference formula, e.g. second order central differences for node i,j:
\left. \frac{\partial^2 u}{\partial x^2} \right|_{i,j} = \frac{u_{i-1,j}-2u_{i,j}+u_{i+1,j}}{(\Delta x)^2} + \mathcal{O}(\Delta x^2)
...solve for u_{i,j}
This sounds like some sort of homework so I hope this helps you how to start with it. Just a hint: The task is finding u, not f. f should be given.
From a fluid dynamics point of view, this task is the discretization of the steady flow of an incompressible medium through a circular pipe.
f is the force or pressure gradient (multiplied by some factor) driving the flow while u is the axial velocity.
Old   September 20, 2014, 23:10
British Columbia
Actually, this is a part of my homework which I'm trying to do, but I'm having great difficulty because I'm not good at math. If you like to help me please explain to me in detail how the solution.
Old   September 20, 2014, 23:17
kabilan.B
kabilan is on a distinguished road
excuse me sir,
in this, you explained ' f ' as diffusive or dp/dx, am i right?
thank you sir.
kabilan is offline   Reply With Quote
Old   September 21, 2014, 05:06
flotus1's Avatar
Alex
I dont feel like doing other peoples homework
And I dont think it would serve any purpose if you copied the solution.
If you show some effort people here will help you with specific problems.
But nobody will write down the full solution for you, especially since solutions to this problem can be found through google.
FMDenaro likes this.
Old   September 21, 2014, 12:27
Thumbs up
British Columbia
Thank you
CFD Salary CFD Main CFD Forum 17 January 3, 2017 17:09
Finite difference can be non-conservative? gregmason Main CFD Forum 2 July 8, 2009 11:53
Difference CFD, Panel methods & Vortex lattice? mimi Main CFD Forum 0 December 7, 2006 09:51
Fininte difference and Finite element Technique Mahendra Singh Mehra FLUENT 3 December 22, 2005 23:49
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
