'Heat Transfer'
Old   October 10, 2007, 13:42
Default 'Heat Transfer'
Fab
I would like to calculate a channel for windshield defrosting without the energy equation by just looking at the flow field. What do you think would be the best variable to look at to judge the performance of the defrosting, i.e. heat transfer? Right now, I would think that a pretty good indicator would be the wall shear stress and the turbulent intensity at the windshield... What do you think?
Fab
Old   October 10, 2007, 15:36
Default Re: 'Heat Transfer'
otd
The convective heat transfer coefficient at the window is related to the wall shear stress by Reynolds Analogy for a turbulent boundary layer. High heat transfer is better (assuming that the heater air is warmer than the glass!). My guess is that:
shear stress sorts 'great HT'
from 'good HT'
from 'so-so HT'
from 'it just freezes over! HT'.
The amount of moisture in the heated air will have an influence as well.
Hope this helps.
Old   October 11, 2007, 00:37
momentum_waves
You may want to be careful assuming that knowledge of a velocity flow field will provide adequate information on the energy field.
The two fields actually may not completely coincide in some applications, although the energy solution uses the existing velocity flowfield values.
This is why, in practice, in a tube for example, there is a velocity profile & a temperature profile - which are generally different.
mw...
<www.adthermtech.com/wordpress3>
Old   October 14, 2007, 13:39
Fab
Hi to both,
thanks for your help! It seems that I can use the shear stress as a first hint and should check it with the energy field distribution... Fab
Thread Tools
Trackbacks are On
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 8 February 26, 2015 05:30
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 19:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
