Finite difference schemes on non uniform grid |
October 12, 2007, 11:47 |
Hi
i have a non uniform grid, and i would like to use a finite difference scheme upon it to solve a collection of coupled PDE's [i.e. use FD method to create a load of ODE's then solve these using Runge Kutta - Method of Lines]. But i am struggling to find a source for finite difference schemes with non-uniform grids, for approximating y_x and y_xx. I have found formulas for central differences, but would also like formulas for backward and foward differences, for both y_x and y_xx - does antone know of a reference that contains these? Or perhaps you could show me how to derive them?! Thanks in advance, Charlie Ryan |
October 12, 2007, 14:45 |
Re: Finite difference schemes on non uniform grid
Deriving them can be done using taylor series expansion.
Assume you want to find the derivative at node i using the points i-1,i,i+1. fx_i = Af_i + B f_i-1 + C f_i+1 your aim is to find A,B,C now.Expand f_i+1 and f_i-1 using taylor expansion and assume (hn=abs(x_i-x_i-1) , hp=abs(x_i+1-x_i) ) f_i-1=f_i-hn fx_i+hn^2/2 fxx_i + HOT f_i+1= f_i +hp fx_i +hp^2/2 fxx_i + HOT substituting back you would get fx_i=(A+B+C)f_i+(-B hn + C hp) fx_i +(B hn^2/2 + C hp^2/2)fxx_i equating both sides u get three equations A+B+C =0 -B hn + C hp = 1 B hn^2 + C hp^2 =0 Solve to get A,B,C and you have the expansion. |
October 13, 2007, 11:13 |
A very good book for finite difference is:
"Computational Fluid Mechanics and Heat Transfer" by Dale A. Anderson, John C. Tannehill, R. H. Pletcher I hope this could help you |
October 18, 2007, 11:32 |
Hi
thanks for your responses - very helpful both of them. One Q - how do you calculate the error [the HOT?], from the finite difference approximation? Thanks Charlie |
On grid independent solution for pulsatile flow | David | FLUENT | 5 | March 25, 2022 03:33 |
turbulent jet simulation | antonio_ing | OpenFOAM Running, Solving & CFD | 5 | September 16, 2010 02:31 |
rhoSimpleFoam | claco | OpenFOAM | 7 | April 20, 2010 04:32 |
uniform grid and beta clustering | rvndr | Main CFD Forum | 0 | February 21, 2004 23:19 |
finite difference method for navier-stokes problem | dallybird | Main CFD Forum | 5 | February 17, 2003 22:00 |
