February 23, 2007, 15:57 |
VSAERO and UAV
I have read a lot of paper using VSAERO for UAV and other CFD related work. It seems a very good software. Can anyone confirm? Is it easy to use?
http://www.am-inc.com/ http://www.aerohydro.com/products/marine/navatek.htm http://www.uavnet.com/DL/Document_Li...ions_Index.htm www.dglr.de/veranstaltungen/extern/aerodays2006/sessions/E_Sessions/E3/E31.pdf Berg |
February 26, 2007, 04:18 |
Re: VSAERO and UAV
Dear Berg, I am using VSAERO since quite a while. I wouldn't say it's a very good software. It works fine for a very limited number of applications. If you want to get drag prediction, forget it (this is true also for almost every cfd software tough!). If you want to use it for hi subsonic mach numbers, forget it. It is relatively easy to use, but you need a lot of experience for the paneling. It's a really old software and it's not user friendly.
December 1, 2011, 00:50 |
james nathman
Rep Power: 14 |
VSAERO's not dead yet.
Imagine doing CFD on a black & white terminal that could only plot wire frames and velocity vectors. User-friendly just wasn't possible when the first version of VSAERO was released. The current version (2009) is 7.5. Al's remarks are correct for 20 years ago, but... In 2004, Gridgen started supporting hybrid VSAERO, so paneling is up to date. Hybrid VSAERO accepts unstructured triangular meshes that simplify meshing wing/body fillets and other odd shapes. The structured quadrilateral meshes were revised by eliminating the assumption of flat panels. Trefftz-plane drag calculations are available for induced drag. Al (is that you Alberto B.?) have you seen Spin, the graphical preprocessor and Omni3d (not omniplot!), the results processor? MSTOP=25 is a great way of evaluating the quality of a grid before doing computation. The matrix solvers now dynamically allocate memory so 30,000 panels are routine (compared to 3000 panels in version 4). Not to mention the huge number of bugs corrected, including off-body, near-field velocities. |
September 12, 2013, 16:09 |
Request
#4 | |
Farrukh Mazhar
Rep Power: 12 |
March 23, 2016, 02:24 |
#5 | |
Rep Power: 10 |
March 23, 2016, 02:30 |
#6 | |
Rep Power: 10 |
would you please provide me this panel code, i want to use it for propellers. Thank you. my e-mail: xieshouruchangan@gmail.com |
