WALL normal velocity
Old   August 16, 2005, 11:30
Default WALL normal velocity
Luca
Hi all! I want to set the tranpiration method which consist in setting normal wall velovity different from zero. I use Fluent and the only way I think is to set volumetric sources in a small cell-layer near the wall bc. I don't know how to calculate the source to be added. Do I have to add a mass source besided a momentum and energy ones? How do I calculate the momentum flux? Is this calculated only on the wall boundary or on the cell faces? Please help, I'm very confused. Luca
Old   October 8, 2014, 05:21
Smile
West Bengal
Anderson101 is on a distinguished road
Hey!!
I am also working on a similar problem, the wall erosion problem in which the species are absorbed and generated at the wall.
Were you able to find a way to apply the wall normal velocity?
Or how did you solve the transpiration problem?
Thanks!!
Anderson101 is offline   Reply With Quote
Wall Normal Temperature Gradient Daniel Tanner FLUENT 6 September 20, 2015 13:10
Defining normal velocity on walls mohsen zendehbad FLUENT 0 July 28, 2010 05:51
Influece of wall velocity in the main flow marvin CFX 0 March 22, 2008 02:05
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
