-   -   Experimental data on transition (http://www.cfd-online.com/Forums/main/14279-experimental-data-transition.html)
kepler October 21, 2007 02:06
I am solving transitional flows and I need some Experimental data to validate my model. Where should I go to find the experimental data on transition? The compressible data is preferable.
Thanks in advance.
Hatef October 23, 2007 07:55
Re: Experimental data on transition
this is a very general question! there are quite a lot of experimental and DNS data on transition which has been done during decades but it mostly depends on the case you are dealing with at the moment. If you specify what you are working on now, it might be more clear...
kepler October 24, 2007 03:13
Hi Hatef,
Thanks for your reply. My work is focus on transitional flows in turbomachinery. The available experiment data is always on low speed but I want get some compressible data.
