Improve the computational cose?
Old   October 23, 2007, 13:50
Default Improve the computational cose?
jinwon park
I am solving compressible inviscid two-fluid flows. To set initial conditions, I nondimensionalized the variables. When I used nondimensionalized initial conditions, I got results in shorter time than I used usual initial conditions. I wonder that the nondimensionalization help reducing computational time as well.
Why do you use the nondimensionalized initial conditions?
Old   October 24, 2007, 08:52
Default Re: Improve the computational cose?
Hatef
I have very little experience in compressible cases and I just think that the nondimensionaliyation in compressible flows, like what we do in preconditioning procedure, mostly relates to convergence problem in low M number. this is just a guess and I am not quite sure whether this is the answer of your question or not.
Old   October 24, 2007, 09:18
George
It also has something to do with the digits that are kept for every variable. It is almost the same difference as using single-precision or double-precision. With the latter convergence comes quicker (in less iterations). For example, if a temperature is 1000. degrees in single precision only 4 digits after the "." are kept.
Old   October 24, 2007, 09:25
Hatef
If you are interested in observing the relation of preconditioning and rate of converged solution in low mach number compressible flow I refer you to paper by Asouti et al under the title of ' low Mach number preconditioning for 2d and 3d upwind flow solution schemes on unstructured grids' Just google it. you'll find freely!
Gruber computational domain k.anand Main CFD Forum 0 April 30, 2011 02:07
Pressure fluctuation in whole external-flow computational domain lordvon OpenFOAM 0 January 26, 2011 08:47
free "Computational Mechanics" noname Main CFD Forum 0 March 2, 2007 07:03
Short Course: Computational Thermal Analysis Dean S. Schrage Main CFD Forum 11 September 27, 2000 17:46
Relation between CFD and computational chemistry Marc Segovia Main CFD Forum 3 May 26, 1999 05:13
