ODD-EVEN DECOUPLING
Like Tree1Likes
  • 1 Post By agg
Old   October 23, 2007, 05:26
Default ODD-EVEN DECOUPLING
Al
Dear all, could someone explain to me the odd even decoupling problem? What it is When it can be found (compressible, incompressible) On which grids Is lumping the only solution? Thank you Al
Old   October 25, 2007, 10:58
Default Re: ODD-EVEN DECOUPLING
agg
ODD-EVEN DECOUPLING is seen for pressure solution in incompressible flows. This is a numerical issue caused by the way derivatives are computed say on a finite difference grid where pressure and velocities are calculated at grid nodes. You can read more about it in the book "Numerical Heat Transfer" by SV Patankar. To avoid this one usually uses a staggared grid where velocites are defined on cell faces and pressure at the cell center.
ugurtan666 likes this.
extrudeMesh - odd behaviour grjmell OpenFOAM 0 September 20, 2011 08:41
help the Gradient odd in zone interface shaoxianjun FLUENT 0 October 15, 2009 22:17
Odd Even Decoupling Validation Sachin Main CFD Forum 1 October 8, 2005 06:58
Odd-even decoupling of cells Peter Main CFD Forum 2 June 1, 2001 13:19
pressure velocity decoupling Frank Muldoon Main CFD Forum 4 February 4, 1999 11:25
