how to discriminate between shear flow and flow with coherent rotation? |
October 20, 2014, 07:37 |
Huang Xianbei
Rep Power: 13 |
Hi,all:
I read the paper "Numerical Modeling Studies of Wake Vortices: Real Case Simulations" 1999 by Shen et,al. And find an extention of the Richardson number for the curvature or rotation effect. However, the expression "can't discriminate between a shear flow and flow with coherent rotation, a discriminator function is applied...". Can anyone tell me something about how to discriminate this ? Thanks Xianbei |
October 29, 2014, 04:09 |
Huang Xianbei
Rep Power: 13 |
Hi, I just have a idea to distinguish them. As in pure plane shear flow, the vorticity should be 0, while in flow with coherent rotation, the vorticity should be non-zero. Is it can be the discriminator?
October 29, 2014, 07:47 |
Jan Östh
Rep Power: 14 |
It sounds like you're dealing with vortex definitions which is a bit tricky.
Check out the work of George Haller, for instance: "An objective definition of a vortex", Haller, G. J. Fluid Mech. (2005), vol. 525, pp. 1–26 That publication will also lead you to earlier work, such as the work of Jeong, Hussain and Robinson. It's great stuff. |
October 29, 2014, 08:18 |
#4 | |
Huang Xianbei
Rep Power: 13 |
Thank you very much for the reference. Vortex definition is a little bit complex which has no good criteria to define it. My purpose is to distinguish the flow region between plane shear flow and flow with coherent rotation to implement a curvature correction of the flow field. So what I need is a discriminator function to fulfill this. Do you know something about it? Xianbei |
October 29, 2014, 09:12 |
#5 | |
Filippo Maria Denaro
Rep Power: 71 |
you can identify a vortex core, for example using the method of http://journals.cambridge.org/action...22112095000462 that helps you distinguish between rotational and shear flows. However, "coherence" is something different, implying statistical analysis |
October 29, 2014, 09:13 |
Rep Power: 18 |
Are you looking for something like the Kato-Launder modification
http://www.cfd-online.com/Wiki/Kato-...r_modification |
October 29, 2014, 19:43 |
#7 | ||
Huang Xianbei
Rep Power: 13 |
Thank you for the link. Kato-Launder modification is an interesting modification for k-e model, while I'd like to implement a curvature/rotation correction to LES model, so the main problem is to define the flow region: whether it's rotational or shear flow. Xianbei Quote:
Thank you for your reply. So in your opinion, the way to implement this is to identify a vortex, right? Then the discriminator becomes a function for identifying vortex: when a vortex appears, the flow is defined as rotational, otherwise, it's shear flow. Xianbei Last edited by wyldckat; November 1, 2014 at 07:58. Reason: posted few minutes apart |
October 30, 2014, 02:24 |
#8 | |
Rep Power: 71 |
The sgs model does not need to act differently in rotational and shear zones as it is supposed to model only small energetic isotropic scales of the motion |
October 30, 2014, 09:54 |
#9 | |
Huang Xianbei
Rep Power: 13 |
Yes, the sgs model is to model small scales of the motion. However,it would be better if additional effects are taken into account. This would improve the complexity and accuracy of the model. In fact, there are many works published focusing on the rotational effect in the sgs model according to the SGS decomposition proposed by Novikov,1992. Xianbei |
October 30, 2014, 11:23 |
#10 | |
Rep Power: 71 |
The model of Lund and Novikov is a non-linear SGS model that is very computational expensive showing no real improvement in practical computational cases...Nowday, I have no news about a practical use in present LES applications. However, it is based on the [S, Omega] tensors that discriminate between shear and rotationale part of the flow. |
October 30, 2014, 19:35 |
#11 | |
Huang Xianbei
Rep Power: 13 |
Well,let's go back to the original problem. I'd like to do a modification of SGS viscosity considering the rotation/curvature effect, so the modification should be only applied to the rotational flow. As you suggested in the former reply, a vortex core would be used to define the rotating part. So the method I should use is the method of defining vortex core to judge whether it's rotational. |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Shear Stress Calculation in the flow. | auburnuser | FLOW-3D | 11 | May 12, 2018 13:49 |
Transient flow with particle injection and the rotor rotation | Clarence91 | Fluent UDF and Scheme Programming | 0 | July 14, 2014 14:12 |
Flow visualization vs. Calculated flow patterns | Francisco Saldarriaga | Main CFD Forum | 1 | August 2, 1999 23:18 |
Free Shear Flow Instability | Lemanov Vadim | Main CFD Forum | 1 | July 5, 1999 14:48 |
